While replacing my front bearings recently, I noticed the lower ball joints and tie rod end ball joints were all very LOOSE! I thought they should be tight (hard to move by hand), but they all are very loose and easy to move. However, they do not appear to be so loose that they're clunky, just easy to move by hand.
Is this normal? Thanks for your help! ![]() P.S. When replacing the tie rod ends (crown nut), I could not find a torque figure anywhere in the OEM shop manuals!!! I used 40 ft-lbs >> Is that OK?
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
Ball joints are very loose after they have been used as in rotatable but NOT as in up and down or side to side movement. I replaced mine when I got the car and the ones I took out were good. As you say they were very free but no slop.
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
