Old 10-04-2003, 09:17 AM
AFBeefcake's Avatar
Subaru Swapper
fuel injectors
I was reading some ware that the fuel injectors used on the svx motor are the same as the ones used on other 2.2 Subaru engines.
Is this right?
If so after market injectors would fit svx motors.
2005 Legacy GT
My WRX's Cardomain Page
Old 10-04-2003, 02:34 PM
Subafreak's Avatar
Superbeast
I though the Nismo injectors would fit from a Q45 or something?
Old 10-04-2003, 10:05 PM
mbtoloczko's Avatar
sans SVX
Yes, the Nismo injectors fit, but they are 550 cc/min capacity which is too high for the SVX motor unless you've got the motor pumping out 400 HP.
Mychailo
Visit my locker
Old 10-05-2003, 10:45 AM
AFBeefcake's Avatar
Subaru Swapper
so is there any one who could find out if older 2.2 subaru motor injectors would fit.
I think the 92 legacy trubo injectors have a higher cc then the stock SVX injectors.
2005 Legacy GT
Old 10-05-2003, 11:00 AM
AFBeefcake's Avatar
Subaru Swapper
well I got the part number for the svx injectors
16611AA310 from www.subaruparts.com
www.1stsubaruparts.com
lists part # 16611AA310 as fitting
Forester 1998
Legacy, w/o Turbo 1992 - 1994
2005 Legacy GT
Old 10-05-2003, 11:56 AM
svxsubaru1's Avatar
i heard you can swap in legacy turbo injectors for the na 2.2 liter.
Subafreak's Avatar
Superbeast
So I guess thats a yes then. Well thats good , if I do trace my starting hesitation down to my injectors I have like 8 spares I could use.
Old 10-05-2003, 12:03 PM
AFBeefcake's Avatar
Subaru Swapper
now that we know the SVX and legacy injectors are the same.
What would hapen if I put turbo legacy injectors in my svx?
would I get to much fuel in to motor or would the ecu shortin the pules and ajust to the bigger injectors.
Not that I would do this any way. I just don't know anything about motor moding and I don't want to messup my car.
2005 Legacy GT
Old 10-05-2003, 07:35 PM
mbtoloczko's Avatar
sans SVX
The idea behind upping the fuel pressure instead of installing larger injectors is that the higher fuel pressure causes the injectors to spray a finer mist. But I have a question for you. You've got an a/f ratio meter on your car. Does it read rich, stoich, or lean at WOT?
Mychailo
Visit my locker
Old 10-06-2003, 07:22 AM
AFBeefcake's Avatar
Subaru Swapper
I don't know the gauge goes blank at WOT. I have not found out why yet.
2005 Legacy GT
Old 10-06-2003, 09:03 AM
mbtoloczko's Avatar
sans SVX
Hmmm. That's a bit odd. What about at something like 1/2 throttle which should also be open-loop conditions? Have you tried reading O2 sensor #1? Have you tried reading the O2 sensor signal using a voltmeter? That might help you to understand what's happening.
Mychailo
Visit my locker
