Old 04-15-2007, 02:02 PM
SVX PlayBoy SVX PlayBoy is offline
Send a message via AIM to SVX PlayBoy
Its looking bad
OK, so I had my engine replaced in December of 2006.
Since then it has never been the same. There is a constant whine from the engine, there is an even worse whine from the powersteering pump. In addition the P/S pump feels like its going to fail. the steering feels heavy when the engine is not revving high, to spin the belt up. The engine also needs to be completely warmed up before ANY performance is seen. I start it up fine, but if I throttle hard, the car CRAWLS. I also have zero top end power, i lose power at 4500rpm. The last problem is that when the car is in drive, the redline appears to be at 5500m not 6500. When it get to 5500-6500, it start "bouncing" around in the higher RPM. I am selling the car, and I want everything to be as close to perfect as possible. I do have a 1 year warranty on the engine, so im hoping that all these problems will be fixed.
Oh, the transmission has a 3 second delay from when I put the shifter into drive, to when it actually engages and the car rolls forward.
Old 04-15-2007, 02:46 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Did the "new engine" include new sensors? It almost sounds like your knock sensors are bad, thus pulling back timing when you try to really get into things. Have you checked the engine for codes? Did the engine come with a PS pump, or did they pull the one off of your old engine?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-15-2007, 03:17 PM
Manarius's Avatar
Manarius Manarius is offline
It sounds like the car is in limp mode! I'd start with knock sensors and anything that the ECU throws a code for.
-Jason
-Obi Wan Kenobi
Old 04-15-2007, 05:54 PM
Romantt8 Romantt8 is offline
If its not a sensor or limp mode, check the cat. Might be clogged.
1992 LS-L Liquid Silver (# 7,083).
Old 04-17-2007, 02:49 PM
-Bill
I dont know about the sensors, but the engine did come with all the accesories on it, and the guys just put the "best" parts on it. Again, not sure of the car is throwing codes
Old 04-18-2007, 11:37 AM
Cats clogged?? The emmision laws dont apply to me, so I was thinking of jsut deleting them. Any opinions??
Old 04-23-2007, 10:02 AM
bump bump bump
Sorry but I need more opinions so I can tell the garage what could be wrong.
Old 04-23-2007, 07:30 PM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
Is the car showing any codes?
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 04-23-2007, 08:07 PM
not that i know of no. dont have the tools to check anyways
Old 04-23-2007, 09:42 PM
davew833 davew833 is offline
What year is your SVX? Unless it's a 96 or 97, you don't need any tools to check your codes.
Here's a link to a how-to
http://www.subaru-svx.net/photos/user.php?How-To|14264
it's very easy. Do yourself a favor- stop guessing and check the codes.
davew833@yahoo.com
Former 6-time SVX owner
Old 04-23-2007, 09:55 PM
well now.... this sounds familiar... Did they by chance change your old coil packs onto the new motor?? If not I suggest they do... also... what year is it??
Old 04-23-2007, 10:26 PM
Thanks, didn't know I could do that, or that it was that easy! It game me codes 13 and 28, which are the cam position sensor, and the knock sensor No.2, respectivly. Now the next steps are...how do I replace them?
Old 04-23-2007, 10:47 PM
i'd say the cam sensor is whats acting up and causing problems... I used to have bad knock sensors going off and it never impeeded performance to the level you describe
Old 04-23-2007, 10:51 PM
I have no idea what they did with the coil packs. It is a 1992
Old 04-23-2007, 11:51 PM
Have you paid them? Are you paying them? Why do they expect to be paid?
