Its looking bad
OK, so I had my engine replaced in December of 2006.
Since then it has never been the same. There is a constant whine from the engine, there is an even worse whine from the powersteering pump. In addition the P/S pump feels like its going to fail. the steering feels heavy when the engine is not revving high, to spin the belt up. The engine also needs to be completely warmed up before ANY performance is seen. I start it up fine, but if I throttle hard, the car CRAWLS. I also have zero top end power, i lose power at 4500rpm. The last problem is that when the car is in drive, the redline appears to be at 5500m not 6500. When it get to 5500-6500, it start "bouncing" around in the higher RPM. I am selling the car, and I want everything to be as close to perfect as possible. I do have a 1 year warranty on the engine, so im hoping that all these problems will be fixed. Oh, the transmission has a 3 second delay from when I put the shifter into drive, to when it actually engages and the car rolls forward. |
Did the "new engine" include new sensors? It almost sounds like your knock sensors are bad, thus pulling back timing when you try to really get into things. Have you checked the engine for codes? Did the engine come with a PS pump, or did they pull the one off of your old engine?
-Bill
It sounds like the car is in limp mode! I'd start with knock sensors and anything that the ECU throws a code for.
If its not a sensor or limp mode, check the cat. Might be clogged.
1992 LS-L Liquid Silver (# 7,083). |
Cats clogged?? The emmision laws dont apply to me, so I was thinking of jsut deleting them. Any opinions??
bump bump bump
Sorry but I need more opinions so I can tell the garage what could be wrong.
I dont know about the sensors, but the engine did come with all the accesories on it, and the guys just put the "best" parts on it. Again, not sure of the car is throwing codes |
