Old 08-23-2007, 07:12 PM
Wikedjuggalo's Avatar
Rebuilding
Broken Bolt, Need Advice
O.k got my new radiator today, was installing it no problem was screwing in the bolts that hold on the left fan. The bolt just snapped on me, there wasnt much force being applied. It just snapped, Any advice on what to do, I tried the damn "E-z Out" and it didn't grab it like it was suppose just made a damn whole in the middle of it (Bolt). Can I use something to else to support it? And Advice is welcomed.
Old 08-23-2007, 07:19 PM
immortal_suby's Avatar
Thread Killah
tighten down the other 3 bolts and call it a day?
Locker Link
2015 BRZ Limited 6MT
Old 08-23-2007, 07:22 PM
Rebuilding
Will I run into problems with the fans moving or anything?
I wont mind doing that but I just dont want my fans going anywhere
Old 08-23-2007, 07:30 PM
Thread Killah
is it a top or bottom bolt that is sheared off?
Locker Link
Old 08-23-2007, 08:30 PM
Rebuilding
There isnt a bottom one, These arent the ones that hold the radiator, its the ones that hold the fan, and its only one. Idk, I might just hold in with one, and try something else.
Old 08-23-2007, 08:33 PM
Thread Killah
ahh - my memory is refreshed. 2 bolts on top, and 2 prongs on bottom. No, I wouldn't feel comfortable with only one bolt on top. Can you try a bigger ez out to get the sheared bolt out?
Locker Link
Old 08-23-2007, 08:39 PM
Wire tie FTW
Old 08-23-2007, 08:53 PM
Rebuilding
Originally Posted by Hocrest
Wire tie FTW
>.> Kinda what I was going on, I mean it really cant move that much and well I have no options, and no time.
Rebuilding
Well, I will have to see, Idk, i will figure something out.
Old 08-23-2007, 08:58 PM
If you screw around too much trying to get that bolt out, you're likely to add another hole to your new radiator
Old 08-23-2007, 09:05 PM
Rebuilding
I mean, I can get some wire, and tire it strong on there >.> its cheap but until I can figure something out, I have no choice at this point. Also dont wanna drill in to it like you said
Old 08-24-2007, 12:58 AM
94SubieSVX's Avatar
OOC for a while
Try glueing a piece of metal in the hole you made in the bolt. Let it dry then try and back it out by using the glued-in piece of metal.
bLAh
Old 08-24-2007, 06:15 AM
Rebuilding
O.k it came down to this, I will post pictures of my amazing MacGyver later, but I come to use some stuff to tie the fan to there the radiator is held into the car.
Pictures explain it better >.>
Old 08-24-2007, 08:26 AM
JaySVX's Avatar
JaySVX JaySVX is offline
If the bolt sheared, i'd just pull hte fan back, cover the remainder of hte bolt with jb-weld or epoxy, and put the fan back in, so that it's holidng.
Good luck.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 09-02-2007, 11:08 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Make sure you use the correct size drill bit before using the EZ out and use a hand tool to screw in the EZ out.
