octain level
if u put a octain level like 150 in ur car can that screw the engine up i did it once and i've never felt so much power from the car i had all 4 spinning. it was expensive but i thought it was worth it showing it off against my buddys wrx. i just wanna know if its worse having that kinda gas through the engine
Ok, not to sound like an A-hole, but you seriously need to clean up your typing. It hurts to read it. I don't recommend using anything much over 105 octane rating. I'm not sure who here has run or is running what octane, but 105 seems like a safe octane level to use in the engine.
Keith
The member formerly known as Civic_Slayer 1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT 1992 Pearly 187K and climbing (11-91) #964 *retired 1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD Everytime I get into my car, it always reminds me that it has POWER |
Can't say as I can answer your question, but you could do worse than reading the four-part FAQ starting here:
http://www.faqs.org/faqs/autos/gasoline-faq/part1/ |
Here's the part from that FAQ that kind of deals with your post:
Shane 92 SVX - Sold 98 BMW M3 Sedan 89 Honda CRX Si w/B16 swap 91 Honda CRX Si |
I would doubt that you had all four tires spinning by just using 150 octane, unless it was in the gravel.
a month? heh.
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker 2002 Mitsubishi Lancer OZ Rally [Nori] 1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling 1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone) 1992 LSL Ebony Mica (Sold to svxcuseme) |
Hey, I had all four tires spinning with just 92 octane!
Okay, so all it meant was that my tires had no tread left and couldn't handle the Seattle rain. |
all 4 tires are spinning every time i drive. they have to be for the car to move.
yea, i know im a smartass
Current: 2005 Black Legacy 2.5i 63k Previous: 1996 Brilliant Red SVX LSi 117k |
Good point there!
Running a very high octane can cause damage in an engine thats not built to handle it. When you raise the octane level, you produce a fuel that burns slower. Meaning, that i will burn longer inside of the combustion chamber. For an engine with a long stoke or high compression, this is great. A short stroke or lower compression engine, this will lead to your valves scorching and your piston rings warping.
In the states, high grade fuel is rated at 91 oct. In japan and a good size chuck of the east this rating is kicked up to 98 oct. Better fuel there for some reason. o.O So, to get the best bang for the buck, dump a bottle of octane boost in with your gas, and then your runing what the car was designed to run. Run anything over 107 oct, and you run the risk of scorching or even melting vital componets in your engine, or at least, fouling your spark plugs realy quickly. Race engine can handle this due to the types of materals they use. Hope this helps with your question |
...and if it's leaded fuel, such as racing or aviation gas, it will foul catalytic converters.
Note item 8.1 in the FAQ: "What causes an empty fuel tank?" dcb |
110 octane story
I ran 110 octane in my car since I could get it for roughly $5/gallon and could afford it. What I can't afford now is the massive power loss I have and the fact that my car now BURNS a quart of oil every weeka and a half or so. Part of this might have something to do with the 160mph+ runs I was doing at the time, but it makes sense that slower burning gas would do bad things to your engine if it's not designed specifically for it.
On a happier note, I'm taking it into subaru for a $300 full inspection next month. Normally it would be $350 or so, but I work at a speed shop and get discounts and stuff. Yay for me. |
2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE Last edited by Mr. Pockets; 07-12-2004 at 08:11 PM. |
