Old 09-26-2006, 11:42 AM
SVX-Oman SVX-Oman is offline
severe vibration-need help (:)
hii , i have problem in my svx there vibration in the gear box when the car is stop and i wana tearn left or right once i press the patrol and turn there is kind of vibration in the gear box dont know what is it i took the car to the dealer of subaru they dident know whats the problem they added Gress a lot of it in the gear box it halped a bit but naw the vibration is back agin wondering what is it
Old 09-26-2006, 11:45 PM
HighwayUFO's Avatar
HighwayUFO HighwayUFO is offline
After 200, it's all the same.
I also have a problem similar to this. I added some Lucas Trans fix(not much), and it is still doing it. The car drives just fine in a straight line, but turning at slow speeds does produce a slight shudder. Any ideas as to what is the cause?
The member formerly known as Civic_Slayer
1992 "Robins egg blue" SVX Originally Claret 147k- CURRENT
1992 Pearly 187K and climbing (11-91) #964 *retired
1992 Pearl SVX 122500 miles #86 FASTAR THAN THE OLD ONE.*SOLD
Everytime I get into my car, it always reminds me that it has POWER
Old 09-27-2006, 07:48 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Replacing the front CV axles cured my low speed shutter on the '94. Not that expensive.
Gene
Gene and Ben
Old 09-27-2006, 03:01 PM
HighwayUFO's Avatar
I already replaced those, and it helped, but it's back again.
Old 09-27-2006, 04:36 PM
Its probably transfer clutch binding, most likely caused by what ever you have done by "removed transmission resistor" in your signature.
Old 09-28-2006, 12:07 AM
HighwayUFO's Avatar
There are a few people that have done it and have had no ill side effects.
Old 09-28-2006, 05:20 PM
I assume that you have disconnected the dropping resistor. When you do this, the transmission reads the throttle to be wide open, so it supplies full line pressure all the time. When you are turning at a low speed,a proportion of the line pressure is applied to the transfer clutch, by the C solenoid.
If this line pressure is higher than what the TCU assumes it is,( because of the disconnected resistor) the line pressure that is applied to the Transfer clutch will be higher than it should be to cause the binding.
Normally when turning at low speeds the throttle opening is low, so the line pressure is low. It is this low line pressure that is applied to the transfer clutch, so it does not bind.
Old 09-28-2006, 07:31 PM
HighwayUFO's Avatar
I once was lost, but now have found out info. So...Connecting it might make that horrible shudder go away in a short period of time...Correct???
