Old 05-13-2005, 01:44 PM
Cappy Cappy is offline
Formally Capuano
Help me decide if I should buy that Aluminum Radiator
I have a 1992 "unmodified" Teal SVX with no filter, cooler, or anything else on the transmission. I had to add a pint of ATF last month & I'm sure it's the original fluid. It's only got 37,000 miles. I also smell antifreeze in my garage on a warm day, after a long ride. The radiator is either leaking up near the cap, or boiling there a bit, because the foam rubber near the top is wet with green fluid. It's been recently flushed and filled (last winter), but it's the original plastic multi-shaded radiator. I asked the Suby dealer to check it out & he just dumped in a can of stop leak.
I've been debating whether or not the get that new aluminum radiator for this car. The fact that it has no tranny cooler could prompt me to do this, rather than spend the money for an add-on cooler. I also have a red '94 with an "all black" plastic radiator (original, as far as I know) with 141,000 miles on it, so I figured I could uses the teally's radiator as a spare if the red one's craps out on me some day.
Sound like a good plan? Does it REALLY only take an hour or two to change the radiator on these beasts? I'm not a mechanic by any means, but I can change a thermostat, hoses, etc. and am somewhat mechanically inclined.
Cap
Cappy
'94 LSi Barcelona Red 158,000 miles
'92 LS-L Dark Teal 47,000 miles
'95 Olds Acheiva 104,000 miles
'85 Audi 4000 135,000 miles
'87 Supra 129,000 miles - 2nd JDM engine
Old 05-13-2005, 02:10 PM
immortal_suby's Avatar
Thread Killah
Yes - it is a good radiator. I'm very happy with mine. It shouldn't even take an hour to change it out the first time. Do somehting soon though - it sounds like you radiator is on it's last legs.
I would have punched him in the butt for that.
Make sure you thoroughly flush the system before putting in a new radiator. You have to get that stop leak gunk out of there.
Locker Link
2015 BRZ Limited 6MT
Old 05-13-2005, 02:32 PM
Earthworm's Avatar
Meow!
I also recommend flushing that stuff out of the system. Is your rad already cracked? There's usually an approx 5" crack going along the top tank of the radiator.
Old 05-13-2005, 02:38 PM
dcarrb dcarrb is offline
Look closely at the top of your radiator and you'll probably see a hairline crack along the bulge in front of the filler neck that's allowing coolant to escape under pressure.
The original radiators had a screen in the transmission cooler that apparently becomes blocked easily if there's no filter upstream; all the more reason to get the old radiator out of there right away.
dcb
Old 05-14-2005, 11:59 AM
Treppiede Treppiede is offline
Best Fix: aluminum radiator (read good things about it, does anybody have pics of it, both alone and installed?)
Good Fix: swap radiators with your other SVX as soon as you can.
Home Depot Engineering Fix: drain radiator fluid. Find the top hairline crack and lightly grind the inside of the crack with a dremel (make the crack like a rounded canal). Sand the entire surface with 400 grit sandpaper, clean all dust with a cloth dampened with a bit of acetone. Mix some JB-Weld as accurately as possible and apply inside of the crack canal and all around it. Let it dry for 48 hours if possible.
The last fix is ghetto but saved me on two similar occasions... I eventually proceeded to get new radiators in those occasions, but the fix was holding up strong.
Remember (this applies mostly to performance upgrades but it's a good guideline nonetheless - don't ask me how I know):
Reliable + Fast = NOT Cheap
Reliable + Cheap = NOT Fast
Fast + Cheap = NOT Reliable
Good luck,
Walter
1995 SVX Green - now 5spd! ..::|SOLD|::..
1991 Talon TSi AWD (~400 whp pump gas)
1993 Civic CX Hatch (daily driver)
1999 Ducati 748S (built 996 engine)
Old 05-14-2005, 06:36 PM
Chris's Avatar
Chris Chris is offline
Founder / Administrator
Send a message via ICQ to Chris
Less than an hour to install for me, probably an hour roughly.
-- Chris
Founder/Administrator SVX World Network
ECU Tune (stage 1), PWR (prototype aluminum radiator)
Amateur Radio - General Class - K7SVX
#1 92 Teal LSl 246k (Dedicated SVX Race Car, now with 4.44 speed)
#2 92 Teal LSl 125k (Retired, car rescued from a field of weeds)
2007 Impreza 2.5i Special Edition, Obsidian Black Pearl (Daily driver)
2001 Dodge Ram 2500 quad cab, Cummins turbo diesel 4x4 (race car & RV hauler)
1985 Honda VF500 Interceptor (fair weather fun commuter)
Going on 11 years of NHRA bracket racing
NHRA Div 6 Car/Driver # T654 (site being rebuilt, new name is www.teamsvxracing.com)
2000 1st Place Club Challenge Series
2002 3rd Place Season Track Champion, Import Racing (Firebird Raceway)
2003 4th Place Season Track Champion, Import Racing (Firebird Raceway)
2003 1st Place NW Regional Import Shootout (July 5th)
2004 1st Place Club Challenge #1 (Firebird Raceway)
2004 1st Place NHRA "King of the Track" race
2004 NHRA Gold Cup 2nd place season win
2004 Import/Sport Compact 3rd place season win
2004 Division 6 Summit/ET NHRA Race of Champions finalist competitor (Mission, BC)
2007 1st Place Import Survival #3
2007 1st Place Track Champion Import Summer Jam (Wild Street Class)
2007 1st Place Import Survival #5
2008 Club season 1st place win, Club Champion
2008 2nd Place Season Import Final.
2008 Division 6 Summit/ET NHRA Import Finals (Woodburn, Or)
2009 2nd Place Import Summer Jam (Wild Street Class)
2010 1st Place Club race #2 - 1st place Sport Compact race #1 & #2
Old 05-16-2005, 06:59 AM
Formally Capuano
Exclamation
Thanks for the advice. I probably WILL get the aluminum radiator as soon as they restock them. I looked again yesterday & could not see any crack along the top of the old one, but saw a single drop of fluid sitting on top, next to the cap. Heck, maybe it IS a bit of leakage. At any rate I can save the old radiator and use it as a spare if the one in my '94 red SVX (with 141,500 miles on it) ever fails. That one's already got a tranny cooler, and radiator bypass on it. Thanks again,
Cap
Cappy
