Go Back   The Subaru SVX World Network > SVX Main Forums > Competition Motorsports
Old 08-16-2010, 11:51 AM
shotgunslade's Avatar
Re: Team ONeill Rally School
I may have misspoken. The 4 day school along with the 6 hour licensing seminar that is included free with the Oneill School, allows you ro register for your Novice License and provides you with 4 coefficient points toward your provisional License. The Provisional license requires the Novice License plus 9 coefficient points. Points are accrued by participating in rally events. It seems that Novice and Provisional Drives cannot compete in turbocharged clases.
Old 08-16-2010, 11:53 AM
sicksubie's Avatar
Thanks for the info...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
