Where Is the EGR Control Valve Located?
I just bought a new EGR control valve solenoid thinking I'd use it as a guide to locate the original one on the engine. After looking around the engine for 20 minutes I dont see it, but I did come across a diagram that shows that its under the passenger side of the rear intake manifold (I tried to copy the diagram here but couldn't).
Is that correct; that I'd need to remove the intake manifold to get to the valve? Thanks. Larry |
Re: Where Is the EGR Control Valve Located?
Hi EGR Solenoid and purge solenoid are under the manifold above cylinder 3&5
ive done it without removing the manifold |
Thanks for the response. Can you give me some pointers for replacing it without removing the manifold? Thanks.
Larry |
'96 SVX LSi needs EGR valve and hoses. Where did you get your EGR?
I'm looking for an EGR valve, part no. 14774AA500; if you found one, where?
This one?
https://www.amazon.com/Genuine-Subar.../dp/B00U0FIPIY Although the picture looks different to the one you posted in another thread. Seems to be widely available, parts.subaru.com, ebay, etc. seem to have that part available. |
You can still get this part# new from Subaru... retail is not cheap however. $100 plus.
Rick 1996 SVX LSI Bordeaux Pearl 222.600 and going |
