Old 12-29-2005, 12:37 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Angry cutting out
Ok, It would appear I am the newest victim of the weird cutting out thing I've read of some of our SVX's. It started on christmas after I put in a new driver side halfshaft and welded up some leaks on the exhaust and has gotten worse today. It stalled like 5 times today while either slowing to a stop or sitting idling and when accelerating it cuts out and completely dies it seems until I let off the pedal and hit it again then it's just fine. On one occasion today it put up a fight to start running again after cutting out while accelerating. After a full stall, It fires up and runs just perfect again. I also did a full throttle run done the road and it was randomly missing a cylinder it seemed, But after letting off and hitting it again it accelerated fine. So are there any answers to this mysterious problem yet? BTW, The only codes in the computer are 32 and 37 and it's been throwing those codes for months now. I had both sensors replaced a year ago. HELP!
Old 12-29-2005, 01:33 AM
Have you checked the fuel filter or air filter.
Old 12-29-2005, 01:37 AM
Budfreak's Avatar
Banned
Haven't checked the fuel filter yet. I have K&N air filter and I just cleaned and reoiled it not long ago. I'll have to try to get a fuel pressure gauge.
Old 12-29-2005, 05:04 AM
billb billb is offline
Jason,
Sorry to hear you're having this problem. As you know I've been fighting this for months. I might have it fixed. Only time will tell. Replacing the MAF seemed to do it. I bought one from a member of this sight for about 60 bucks. New ones are over 300 now. I had tried cleaning my old one and it had no effect.
No stalls in about 3 weeks.
Bill
94 SVX LE 130,000mi
Old 12-29-2005, 08:41 AM
mbtoloczko's Avatar
sans SVX
Originally Posted by budfreak1
... I have K&N air filter and I just cleaned and reoiled it not long ago...
I'm guessing that the oil from the K&N air filter crapped up your MAF. This is a common problem with oil-type air filters and MAFs. Try cleaning the MAF with some electronics-grade solvent (CRC QD Electronic Parts Cleaner).
Mychailo
Visit my locker
Old 12-29-2005, 09:43 AM
n00b on demand's Avatar
Yeah I stopped using the K&N....i just use a regular filter. Would the STi panel filter be the same as a K&N?
Old 12-29-2005, 10:54 AM
I have seen the panel filters and they are paper ones without oil. I know that they also have the panel ones with oil, so as long as they don't use oil, I think it would be safe.
