SVX 4EAT to WRX 5MT swap underway!
Thought I'd start a new thread on my 5 speed swap status. I got the 4EAT out last night after about 1.5 hours of sheer hell. I should have removed at least one half axle...hindsight.
Anyway, started reading lots on the most recent swap by rmjjensen. I hope he figures out his drivebility, noise, vibration issues. My take way on all this is that I should spend a good bit of time setting up my trans mount, right? I have both the SVX mount and the entire mount from the 2002 WRX. For those who have been driving the 5 speed for a while, is the ride good? One of the things I like most about the SVX is the ride...smooth. Never had a real smooth ride from my GL, XT, or legacy. All were/are fun and peppy (legacy excluded) but none are as smooth as the SVX. I'd just like some reassurance that the 5 speed swap is worth all the effort. I hate the 4eat and it's flakey shifting/slipping. My hope is that I don't create more problems going to 5 speed. Next steps are to get the 5mt mocked up and sitting on the engine so I can measure total drive shaft length needed. Is anyone driving a 5mt within a couple hours driveing distance from Atlanta? Thanks again for all the help. This site is great. |
if u wait a little while My buyer lives in Georgia... he will have my 5mt...
Yes you do lose a little rid equality with the newfound vibrations of the 5mt swap... Then again I have Group N mounts all over the place... My 6mt is not too bad but still has a little vibration. Good luck and feel free to ask any questions... many people on this board have done excellent jobs on their 5mt swaps Tom |
I still have all the stock mounts installed (for now) and my SVX is as smooth as any other. (not counting the suspension upgrades)
I believe the MT's are harder on the mounts (engine/tranny/diff) though as you can shock the drivetrain more with a clutch than with a torque converter.
Agree! I realize I'll sacrifice a little ride quality moving to MT but just don't want it to be overly vibratory...although my wife might enjoy the ride a little more ar ar ar !
I'll get some picks up once I get the mount fashioned. My digital camera is on the fritz so it might be a while. EDIT: Forgot to ask. Any of you guys have recommendations on the clutch. I was planning on replacing it and the throw out bearing. I'm going to stick with the WRX flex plate as it is in good shape. Last edited by svxcuseme; 11-29-2005 at 11:37 AM. Reason: added question |
I've got the STi Group N motor mounts and tranny mount, and my car is still very smooth at normal cruising speeds. I think that in many instances, vibration issues can be traced to a bad driveshaft or improper driveshaft u-joint angles. A poorly aligned driveshaft can vibrate horribly at speeds as low as 60 mph.
For the clutch disk, you'll want to get something with an organic, full-circle clutch disk. If you're not upgrading the pressure plate, then you're probably fine just sticking with a new stock disk.
Mychailo :: 2006 Silver Mitsubishi Evolution 9, E85, 34 psi peak, 425wtq/505whp DJ :: 1995 Laguna Blue SVX L AWD 5MT (sold) Visit my locker SVX Mods: ND iridium spark plugs, Impreza RS fpr, afr tuned to 13.2:1 using a custom MAF bypass, custom exhaust, WRX 5MT w/ STi RA 1st-4th gear & stock WRX 5th gear, Exedy 13 lb flywheel & Sport Clutch, STi Group N tranny & engine mounts, urethane spacers in rear subframe, rear diff mounts, and pitch stopper, SVX Sport Strut Springs (185f/150r), custom 19 mm rear swaybar, urethane swaybar mounts, Rota Torque 17x8", 225/45-17 Proxes 4 tires, Axxis Deluxe Plus organic brake pads. Last edited by mbtoloczko; 11-29-2005 at 12:20 PM. |
Questions - Status update - To do.
O.K. Manarius's Legacy excluded. Maybe I can get a ride in your's and eat my words.
Questions: I got a 96 Outback Drive shaft. It fits perfect !!! - I assume the carrier bearing flange needs to be cut from the SVX DS and welded to the Outback DS to bring it higher in the tunnel, correct? - What part of the Outback DS needs to be cut off to give it more freeplay? Is it the actual shaft tip or the cup. I doon't see how cutting anything off the cup will help as it is bottoming out on the shaft tip as it mounts to the 5mt. Thanks in advance. Status:-Pedal assembly in. I extended the Brake and clutch brackets rather then the upper flange. This gives the pedals the perfect height and travel. - Clutch MS in! - Brake lines bent. Much thanks to Jason Letbetter's brake line bending tool...A must have! - Transmission in. To do:- Finish making trans mount cross member. I'm going to use parts of the WRX member along with the SVX rear mounting bracket. Looks like I'll have to fabricate the front cross member. - Finish shift leakage extension. - Cut/Shave DS tip or cup? - Install Shifter and boot. - Drive this mofo out of the garage !!!!! Thanks for all the help thus far! Marc Last edited by svxcuseme; 12-23-2005 at 11:26 AM. |
I believe the cup needs to be shaved. This is the first time I will actually be doing a 5mt swap so I am also using a legacy shaft. If need be it is easier(cheaper) to cut a shaft shorter than make it longer... I need to take some measurements before I go installing anything. There are many good X-member ideas out there just do a search and look for pics. My "Beginng of the 3rd 6mt" Thread has some pics but not too detailed to say the least... Well good luck and feel free to ask more Q's
Tom |
cut cup - shave trans output shaft (96 Outback DS)
Tom you are correct. I also need to grind down the transmission output shaft. I pulled the bell shaped dirt/grease gaurd off the back of the trans (came off easily) so I could see exactly where my drive shaft (DS) is bottoming out.
I'm hitting the output shaft of the trans. Looks like I have two options.
I'm going with option 2. That will give me the needed free play with no added expense. Looks like cutting the cup is not the only mod when using a DS from a manual 96' Outback with a 2002 WRX 5mt. More to follow ... |
Regretfully...
Shaving the trans output shaft gave me some clearance but not enough. It still binds when trying to install it. The drive shaft is at a local drive line shop. They are removing 3/4" from the front section and balancing. More to follow ...
