Another overheating thread
I was out driving today, (about 50 degrees, sunny) and got stuck in traffic. Everything seemed OK, until I looked at the temp gauge, and it was at 3/4 of the way up So I pulled over as fast as I could, and took a look at things. Here's what I found...
Both fans were on, and working normally. Overflow tank was beyond the full mark, but not bubbling / boiling or anything. In fact, I dipped my finger in it, and it was barely warm. Radiator cap / top of radiator felt warm (not hot) I could put my hand on the intake manifold with the car running and leave it there (warm, not hot) Upper radiator hose was warm Oil on dipstick / under cap looked fine No leaks at all. So, I allowed it to cool down for a few minutes, then decided to turn back and drive it home (with an eye on the temp gauge, and the heat on full). I noticed that when I was idling / moving slowly, the temp would go up. But at expressway speeds, it dropped to normal operating temp and stayed there (never went below normal). The car drove fine - I wouldn't have even known anything was amiss unless I looked at the temp gauge. The radiator was replaced last summer with a new one. Water pump / thermostat are unknown age / mileage. Although I would guess that the thermostat is probably OK, since the temp never went below normal when I was on the expressway. Does anyone know what this might be? I'm suspecting either the head gasket, or water pump. God I hope it isn't the head gasket. I have no idea how I'm going to fix that here if it is.
Re: Another overheating thread
I had the exact same thing and I replaced the T-stat and rad cap with new OEM parts and it never happened again. It would be 3/4 the way up and only raise at lower speeds but faster speeds it went to normal. My old T-stat that was 2 weeks old from Subaru would only open so much, and not full at temp. Also the rad cap 2 weeks old was junk from Subaru. Here's the thread...http://www.subaru-svx.net/forum/showthread.php?t=51144
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 03-07-2010 at 06:45 PM. |
cheapest thing to do is replace the t-stat and rad cap and cross your fingers hoping it's not a head gasket.
i have a brand new rad cap if you want it
Thanks for the replies, everyone. I went out just now and looked at it again after it had cooled down completely. I fear the worst.
No coolant is visible in the radiator, but the overflow tank remains nearly full, even after fully cooling down. I blew through the hose connecting the overflow tank to the radiator - seemed a bit tough to blow through at first, but it's fine now. I sniffed the radiator fill neck with the cap off, and it smells like exhaust. As far as I know, the only thing that can make your coolant smell like exhaust is either a bad HG or cracked head / block. So, I think it's done. I guess now I'll have to either read up on how to change a head gasket, or bend over and pay someone to do it / help me do it that isn't too far away. At least it got me through winter, I guess.
Here is a suggestion on something to consider...
Pay someone to do it could cost about $2000 + You can buy general tool set (craftsman at any sears) expensive side would be say $169 Harbor freight engine lift $180-250 harbor freight engine stand $50-60 Dealer engine reseal kit I can't remember the exact cost but atleast $250 add in lets say another 150 for misc. sensors or hoses etc. DIY Low side $799 (and not all spent at once either) high side $879. You keep all the tools or resell what you don't want. See paying someone else just doesn't make much sense to me. If you have some mechanical experience, a manual (yeh even chiltons), and the forums you should be able to do pretty much anything to these cars. Just my $0.02 |
