Old 04-04-2017, 10:10 PM
required required is offline
mmm, hotcakes!!
WTB: 96-97 obd2 ecu
I'm looking for a dead obd2 ecu to cut up for an adapter to put an earlier ecu into my 97 when I swap I'm my 6 speed transmission. I would also be interested in a known good obd1 ecu, with enough harness to make said adapter. Thanks in advance.
-Tag
Old 04-04-2017, 10:22 PM
Tireiron Tireiron is offline
Re: WTB: 96-97 obd2 ecu
You can also find the same slip lock connector on the OBD2 legacy ECUs from the 90s. I got one from a 98 to strip for the connector. Much easier to find. I wouldn't be surprised if the OBD1 ECUs from the legacys use the same connector as the SVX OBD1 ECUs.
Old 04-05-2017, 05:31 AM
mmm, hotcakes!!
Thanks, I was wondering if those were similar. I think they're pretty cheap on ebay, I still am interested in getting an obd1 ecu with a wiring pigtail.
Old 04-08-2017, 02:19 PM
mmm, hotcakes!!
Still looking for an obd1 ecu and harness.
Old 04-08-2017, 05:15 PM
Blacky Blacky is online now
I've got an OBD1 ECU in my parts car and I can cut as much of the harness as you want.
I promised it to fasteract7 but he is trying something else before he buys it for certain.
I can sell it to you if he backs out.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 04-10-2017, 05:59 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Blacky,
My 92 has decided to run properly after 3 reman. injectors ( yea, I know I should have replaced all 6 !) so hopefully won't need your ECU for now. Thanks for the offer.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
