Another dead Trans???
Well, the trans in Melis's car has started acting up after about 3 weeks.
About a month ago, I removed the trans to replace the front diff. While it was out, I adjusted the brake band to spec (6'#'s then back 3 turns). For a few weeks it shifted great, in all gears, smooth as can be. Earlier this week she mentioned that it would slip in 1st and 2nd under hard acceleration. I told her to try it with the selector in 2nd, and that seemed to help the slipping. By the time I got here to look at it on Thursday, it was starting to slip no matter where the selector was. I checked all the lines for kinks, pulled the resistor and tightened the brake band about a turn. I also checked her TPS, there was a dead spot, just above idle, so I swapped that out. It is slipping in all gears, including reverse. It seems like it's not getting pressure. I'm getting it towed to my place so I can pull the pan and check the internal filter. Anything else I should check??
Dave/Melis, Sorry to hear about the trans...slipping in all gears is not a good sign... -Bill
make sure there is a good o-ring on the filter... If not you are sucking bubbles
Tom |
Sucks Dave and Melis. Sorry
Down to none |
Melis must be fit to be tied! After all, she just got Peej back on the road.
[SIGPIC]http://www.subaru-svx.net/forum/image.php?type=sigpic&userid=5569&dateline=1207440 507[/SIGPIC] Naught but by the grace of God "42" Current Stable By Age:'89 Subaru XT6 Silver "Audrey" as in Hepburn '96 SVX LSi #767Brilliant Red "Lil Red" Now on the front burner. Looking for a totalled, but running parts car. |
Replace the main line pressure control solenoid (A) while you are at it and reconnect the resistor.
If you do this please report the result.
Well it's a good thing the asshole that did her last tranny job warranties his work
Before I tore into it today, I decided to doublecheck the ATF level... the dipstick's dry. I just checked it before the issue started and it was full. It did not leave 3+ quarts of ATF on a puddle or in a cloud.... Check the front diff, it's full of redness So I drain the diff and refill it with not ATF'd gear oil. Add 2 quarts of ATF to the trans and take it for a little drive. She shifts like a dream So... back off with the trans, back off with the front diff and use NEW seals. What do I need? I know I shouldn't have reused that tube with the rubber on each end (I did used permablack on it ) What other seals do I need, I don't want to do this again.
its probobly the pinion seal.... Thats my guess
Tom |
I know 9 and 16 on this diagram (I did replace 9 the first time )
Any others?? How about anything from this diagram?
I think only 20&21
Tom |
Fixed it from your phone call.
So that's; 9 - 80670050 - Oil Seal 16 - 31295AA003 - Seal Pipe 20 - 31348AA000 - Oil Seal Retainer 21 x 2 - 806752020 - Oil Seal 1 - 31339AA122 - Gasket
sounds right
Tom |
