Front knock Sensor (1)
Need one knock sensor for the front, by the alternator.
Hopefully this'll cause my car to lose it's misfire and shakiness. |
Re: Front knock Sensor (1)
Rock Auto has them for $28.
oh reary? Thank you!
NP, do a search for "rock auto discount code" to save 5%.
Are you sure it's a knock sensor and not a faulty spark plug wire/connection...that was my issue, switching out the plug and resolved the problem...GL
replaced all my plugs about 50miles ago.
How can I get it out?
From the looks of it, a combo wrench should do the trick...
If you got a camera down there I am assuming you can fit your hand.
iphone, and i can BARELY get my hand in there. 12mm combo wrench is just a bit too short. Plus, the sensor thats in front of it where the knock sensor plugs in, is in the way.
Did you remove the alternator?
yes..I cant get the bolt to budge
