Old 08-26-2009, 11:07 AM
jjanak79's Avatar
jjanak79 jjanak79 is offline
transmission problems
i bought my svx and about 400 miles later the tranny is leaking. I think its the 2 intercooler hoses that are rubber but it seems like the pan is leaking too. I checked the pan bolts and they were loose. Has anyone seen this crap before??
Old 08-26-2009, 11:39 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: transmission problems
Yeah.... it happens. Replacing the rubber lines and tightening a few bolts is pretty easy.... You may need to get a new gasket for the transmission pan and use threadlocker on the bolts if it still leaks.
Compared to other things that could go wrong, this is nothing to stress about....
Old 08-26-2009, 11:42 AM
jjanak79's Avatar
Have you had this happen to you?
Old 08-26-2009, 08:09 PM
Green1995SVX's Avatar
Be careful not to over torque the trans pan bolts or you can distort the pan itself. I'm sure somebody will chime in with the proper torque specs.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 08-27-2009, 06:22 PM
NiftySVX NiftySVX is offline
Mike's right about distorting the pan, this is common. There are two different gaskets for the trans pan. I am not a fan of the cork one, I always used the neoprene one, I would suggest replacing yours with that one and torquing the bolts to about a half turn past finger tight.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 08-30-2009, 11:40 AM
jjanak79's Avatar
Where do i get the gaskets from?
Old 08-30-2009, 12:24 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Subarugenuineparts.com
1stsubaruparts.com
Rockauto.com
Dealer.....
Call around to Autozone, Kragen, etc.....
