Identifying 5 speed transmission
Hey all I was wondering how I can identify the transmission I just bought. It's supposed to be from a manual 5 speed wrx. The only two things I can find on it is FM-5 stamped on one side and FM-3 stamped on the other side. In addition there is a number 587465 on a sticker near the bell housing. I need to find out so I can get the correct wiring harnesses for it, and any other things it may be missing. Thanks a ton everybody.
hey
hey justin this is paul, read your pm
Sent you a pm back Paul. If you don't see it does the number I'm finding on the tranny of 587465 somehow crossreference to the wrx tranny number you got of TY754VN2AA?
does the clutch slave cylinder point toward the front or the rear of the trans??
Tom |
Hey Tom I checked out the tranny and the clutch slave cylinder points toward the rear of the vehicle, that tell you anything important about it?
