Old 08-04-2012, 03:51 AM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Unhappy Anti-Lock Brake warning light and buzzing noise
Sigh.
It was going well too.
I have done a quick search, but what does it mean when the anti lock brake light comes on and the ABS unit under the bonnet starts buzzing?
I have disconnected the battery for now, to stop the buzzing.
I assume that the unit has just self destructed.
Any positive words?
Mike
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 08-04-2012, 06:58 AM
Re: Anti-Lock Brake warning light and buzzing noise
It's just a sticking ABS relay. A simple solution where you probably don't have to replace anything. If the relay needs replacing, it is very simple. Instructions and part numbers in the link below.
http://www.subaru-svx.net/forum/show...94&postcount=3
Old 08-04-2012, 07:02 PM
oab_au oab_au is offline
Don't know for sure, but I thought that, the relay was just a normal Bosch relay.
One Arm Bloke.
Tell it like it is!
Old 08-04-2012, 09:38 PM
BRADY's Avatar
SVX Addict
Thanks for the help, lads!
I have struck it with my knuckle. It seems to have fixed it!!!
THANKS AGAIN!
Old 08-05-2012, 06:09 AM
aust92pearl aust92pearl is offline
THANKS AGAIN!
punching things always helps
helps relieve frustration
and sometimes fixes things too
Old 03-03-2013, 06:53 PM
SUPER SUPER is offline
This problem just happened to me. Gave it a rap as suggested and it's fixed for now. I love it when a little aggression actually fixes a problem...
Also, this is why this site is so valuable. Got my $ worth annual dues and it's only March. Thanks for the resource.
Old 03-03-2013, 08:57 PM
Tapani Tapani is offline
Wow, had to pull the ABS fuse for this on Friday and haven't found time to diagnose. I bet my problem is exactly the same because the pump kept running even with the ignition off.
What a coincidence !
Tapani
Old 03-03-2013, 09:29 PM
Tapani
I pulled the fuse and it kept going! So I ran in to the computer and looked it up. fixed in 5 minutes.
Old 03-03-2013, 11:40 PM
You pulled the 45 amp fuse and it still kept running?
/T
Old 03-04-2013, 12:16 AM
/T
No. Pulled the 20 amp ABS fuse. It kept buzzing with engine off.
Old 05-05-2014, 09:09 PM
Had it happen again, except I did not hear it and it drained the battery. Thinking I should replace it.
