To Houston and back.
I've decided to visit some long lost relatives, and drive the beast from Baltimore to Houston & hopefully back within a 9 day time frame. Total mileage looks like around 3K. Let's see, 1. if I make it. 2. What do it cost? Starting line - '92 with 84K & no KNOWN problems. Just installed a B & M cooler & changed oil. I don't want to see a computer or answer a telephone 'til I get home. Full report later. Auf Wiedersehen. Tsu.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Bon Voyage
Travel safely. Enjoy some barbecue while you're there. Otto's or the Goode Co. are a couple of my recommendations.
bill Green 95 SVX - Cleo Green 97 Outback - Maxine Red F-150 Extended Cab Long Bed - Big Boy Even the best monkey sometimes drops his banana. |
good luck, hopefully you will not need it.
it is going to be really hot and humid in houston. in memphis it is about 80-85 degrees and humid as hell. have a safe trip and give us the full report when yuo get back.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!! "Too much fun to drive!" |
Re: good luck, hopefully you will not need it.
i know exactly what you mean.
it gets blazing hot here in memphis. i hate it when the humidity is really high because it feels like as soon as you walk outside you are sweating. hot and sticky is not a good combination......that didnt read well did it......
