Old 10-09-2003, 12:33 AM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
Factory Spec Temperature....
What is the factory spec for the operating temperature for the 4EAT in the SVX?
I've been getting consistant 240 degree op. temps, even with a large tranny cooler.
Help anyone?? Iwant it to stay under 190!!! I don't care if I overcool!!
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 10-09-2003, 12:46 AM
mbtoloczko's Avatar
sans SVX
Re: Factory Spec Temperature....
I'm not sure that Subaru recommends, but it is generally agreed that the optimum temp for non-synthetic ATF is between 170F and 200F. You can go maybe 20F higher with synethic.
Mychailo
Visit my locker
Old 10-09-2003, 07:46 AM
240!!! yikes!
here are two things you can try:
you may want to insulate your temp sender - i did to mine and the temps seem to drop 10-20 degress from what they usually were. i think it was picking up heat from the engine - it depends where yours is situated.
remove your belly pan. you'll see a big drop in temps and the temp will drop quicker, too. i'm going to put mine back on for the winter to keep the salt and crap off of my stuff underneath.
1987 928 S4 (Black) SOLD!
1997 SVX LSi (Ebony) SOLD!
2013 G37xS (Obsidian Black)
Old 10-09-2003, 05:12 PM
svx_commuter's Avatar
Is that with normal cruising or driving hard? What's the ambient air temp for the 240F? In normal cruising I run about 100F above the air temp. When it gets to be 98F outside it can hit 230F going up hills. The engine thermostat opens at 180F so if your driven hard or racing on a track, 240F is pretty good.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-22-2003, 07:58 PM
You can also change how your tranny cooler is hooked up (parallel<-->series<-->disconnected) to see which setup is optimum for you.
I can only assume you get these temps in city driving.
I normally see a max of 210-215°F in city driving with no aux cooler.
Old 11-21-2003, 09:48 AM
tlemmons
I have the same problem per say. My trans temp holds the 210-240 mark alot. I drive mountain roads so my driving is a little harder on average them most. I have an external cooler and have tried with and without the built in cooler in series (have not tried parrellel). External temp does not seem to have much effect except maybe to extemes.
My first thought was that there was restriction in the lines that did not allow for good circulation but when I removed a line the flow seemed good but not under much pressure. I don't know if this is what it should have been or not (anyone?).
Let me know if you find anything since from the sounds of others this is really running on the hot side. If I drive hard I can get it to the 260 mark on my gauge!
