Old 10-24-2003, 07:25 PM
alltrac alltrac is offline
cover guide
Its the black plastic shell that has the AC and alternator wires. Mine is broke does anybody have a part number?
Victor
Old 10-24-2003, 07:38 PM
can you get a picture of it?
Old 10-25-2003, 05:23 PM
Earthworm's Avatar
Meow!
Good question! I've just looked all over subaruparts.com for the part but can't find it.
Earl, it's the hard black plastic that clips around the alternator wires above the A/C compresser. It's about 7 inches wide. Mine is broken as well and is out of place (going over the hard A/C pipes) wearing a hole through the hood insulation.
Old 10-25-2003, 06:38 PM
lee lee is offline
I couldn't find it either.
Mine was broken up when I bought the car so I got some of that round split loom plastic stuff. You can pick it up anywhere, i.e., WallyWorld, parts places, etc.
Not stock, but it works I think I used 1/2".
Old 10-26-2003, 01:02 PM
I have been researching that part for over a month. It does not exist in any Subaru database that I know of. There is no part number or other configuration that you could use to begin a search from. Russel Subaru had no luck checking with other Subaru databases and searches by my Japanese contacts with FHI turned up nothing as well.
I used aluminum coated plastic wire loom called "convoshield" to run the wires through. It will withstand direct temperatures in excess of 500 degrees
Old 10-27-2003, 08:15 AM
wire guide
Thanks everbody, I too had no luck searching. I guess were all in the same boat.
Victor
Old 10-27-2003, 10:02 AM
Here is a photo of the elusive part. (I got this photo out of Nubs locker. His seems to be intact for now...)
Old 10-27-2003, 11:42 AM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Wink
Hey, John - Since I have one in new condition, do you think I could get $100.00 for it? Of course it still has the car attached, but for this EXTREMELY RARE GENUINE SUBARU SVX part, I'd make a few sacrifices.
Ron (black duct tape on my mind).
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 10-27-2003, 02:11 PM
JLittell
Yep...I searched for that too a few months ago. What has everyone else used to replace it?
John (Thinking black duct tape has better uses than being on a SVX!)
Old 10-27-2003, 02:26 PM
Mr. Pockets's Avatar
Moderator
Mine came apart when I tried to remove it over a year ago. I haven't replaced it with anything.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-27-2003, 02:39 PM
JLittell
I would be wary if you had these wires exposed..
Maybe using some type of insulator (extra black electrical tape?) ... and then consider using a round black plastic wire cover?? Heat seems to the main culprit here...
