Old 02-16-2010, 09:35 AM
BDSDC BDSDC is offline
Re: EGR temp sensor cleaned
Thanks,
Nothing is ever easy with this car...anyone have a picture of the temp sensor at the egr? The manual I have doesn't.
Doc
Old 02-16-2010, 09:01 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
That ones easy, it just looks like the top of a bolt with wire to it. The only other place it would be if not in the pic is the side of the EGR itself.
If you want to do the hack shortcut way of cleaning those passages, just remove the EGR piping or temp sensor if you find it and spray brakeleen into it while revving the engine so it doesnt stall. Just keep in mind the gook and grit thats in there will be spat into the engine, so if you like your car I would just do it the right way.
Have you looked at the online manual yet?
Old 02-22-2010, 02:43 PM
Wocketman Wocketman is offline
Forgive the ignorance here....but just what exactly does the EGR valve/temp sensor/system do anyway?
What does it mean that those pipes/sensor are all gooped up, where did that stuff come from...I can't imagine the exhaust being that oily...does it mean that the system is back-feeding from the crankcase?
Bruce Schwab
Recovering solo ocean racer
www.bruceschwab.com
On land: 92 Ebony SVX, 188k
Old 02-22-2010, 07:36 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Generally speaking, the EGR system basically recycles engine exhaust, which is essentially inert, back into the engine combustion chamber to take up space, allowing the air/fuel charge to be smaller and allowing better fuel mileage under low to medium engine load.
The goop is a normal by-product of combustion chamber soot and burnt off oil that is recycled thru piping that does not reach a high enough temperature for it to be burned "dry", it just collects over eons of engine operation and eventually impedes the exhaust flow past the temp sensor. Then the ECU thinks theres a problem with the EGR valve itself and kicks on the engine light, as in my case.
Old 02-24-2010, 10:34 AM
Ah, makes sense, thanks.
Bruce Schwab
www.bruceschwab.com
