Old 07-29-2019, 02:04 AM
SVX99 SVX99 is offline
Fuel Sender Unit
I think I have found the problem with my fuel sender not working properly. It has worn contacts.
First photo is from a forum post I read which shows the intact knob at the end of the contact and second photo is my worn one with some "Devil horns" of copper left at the end.
Obvious get a replacement part is hard to do in Australia (only 249 SVXs ever officially sold here).
Normal solder will work but probably won't last as it is soft.
Copper solder would be better but you need a blow torch to melt and that could damage the plastic part.
Any suggestions to fix?
Old 08-05-2019, 07:59 PM
Re: Fuel Sender Unit
Well I tried a couple of ways. Made a mold of the good sender unit and tired copper solder but it was an epic fail as everything melted (Copper solder melts at 700C!). Went back to normal solder which worked reasonably well and has tested ok. The Devil's horns are important to hold the solder in place so do not remove them if you find your sender unit has the same wear as mine (which it should).
Old 08-06-2019, 04:13 AM
theflystyle's Avatar
Thats great! Did you re-install yet?
1994 SVX LSi
2008 Legacy 3.0R
Old 08-06-2019, 05:51 AM
Are there not any other newer Subaru fuel senders that can be used?
Old 08-08-2019, 11:20 PM
Sky9pilot's Avatar
Sky9pilot Sky9pilot is offline
2005 is a long time ago...has there been any new supply of the fuel sending units for the 1996 SVX's since then? I'm needing some repair for my gas guage doesn't always work and sometimes right after a fillup will drop to empty then if I hit some bumps in the road the guage will recycle to full or partly full.
Sky9pilot
Old 08-19-2019, 02:44 AM
Yes, all back installed and the fuel gauge works!
Old 08-19-2019, 04:22 AM
Congrats!
That has to be a great feeling.
1994 SVX LSi
2008 Legacy 3.0R
