Old 12-14-2013, 11:29 PM
Re: JDM SVX Headlamps
Ok, one UK light has broken tabs on its side, so I will be taking it apart shortly.
Will post pictures and we will take it from there. Thanks John and Armando.
Old 12-15-2013, 03:12 AM
There u go, found the difference:
The rest are either identical or carry the same part numbers.
Old 12-16-2013, 07:27 AM
SVX_MY_BABY's Avatar
How difficult was it to get these plastic bits out? May be worth looking at Right hand lens and switch to left?
Peter
Old 12-16-2013, 10:09 AM
Those are not plastic, they are metal.
When you torque the long upper screw (where the "L" shape leveler is) as well as the middle lower one both from the back of the headlight, you can get all the frame that holds the lens out. There is also a ball joint in the middle upper frame that holds the inner lens.
That is of course after you remove the outer front Yellowish cover out.
I can give them a 7/10 in terms of difficulty.
Now with the UK headlights, the middle back screw is replaced by a motor. Torquing it in place will be a challenge. Let me get back to you when I am done with the first headlight.
Old 02-02-2014, 03:51 PM
Guys, anyone with the wiring diagram for the adjustment mechanism/button of those headlights?
