Old 08-10-2010, 03:48 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Power Mode Selection
Originally Posted by NeedForSpeed View Post
Another mystery solved, learn something NEW about these cars everyday
Now its time to see what [if anything] happens when the gauge cluster is swapped for an earlier one
OR, to see if the the power bulb is missing and taped over,
OR, even if the stencil is there,
OR, OR,,,,
Is the power light wire present in the TCU harness? If so then try swapping in an earlier TCU and see if the light starts working.
The 97 is a different unit to the earlier models. I suspect it doesn't have a spare digital output to drive the light, or at least not on the right pin.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-10-2010, 04:34 PM
cdvs cdvs is offline
I recommend caution. I did investigate swapping an earlier TCU. The connectors do match. There were several wiring issues that I wasn't able to resolve w/o a OBDII diagram. At least one stopped me from just swapping. I'm taking a different path and dropped this approach before answering those questions.
Anyway, when you shine a flashlight at the legend strip of our '96, with the lights off, nothing shows between 'check engine' and 'manual'. 'Power' is to the right of 'check engine' on our '92s.
Btw, the TCU sinks the dash lights. (provides ground)
Old 08-10-2010, 05:07 PM
Old Fogey
OK, just used the same "flashlight" method mentioned by cdvs to check my '97 cluster and though I can see a very faint "Power" between "Check Engine" and "Manu", there is no color there, only, maybe?, a stencil cut-out. Owners manual has no mention of the feature in the display section.
Thank you to cdvs for answering the Trans codes question!
Glenn
Old 08-10-2010, 05:21 PM
NeedForSpeed NeedForSpeed is offline
Which wire or wire position is the 'power light' wire? thanks
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-17-2010, 08:06 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Question Re: Power Mode Selection
I'm attempting this right now on my 97, and trying to use the manual button as the switch. From what I've gathered in this thread I should be able to depin the brown/black wire from the A6 position and move it to the A4 position. I'm having a lot of trouble removing the pin, any tips or tricks to get it out? I've been using a little tiny screw driver to pop open the clip on top and attempt to remove the pin.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 08-17-2010, 08:21 PM
First, unsnap the cover on the side you want to remove the wire. I seem to have good luck using a small finish nail as a pic, insert into end of plug, gently pry in the right direction to release the internal clip as you pull on the wire.
Old 08-17-2010, 08:28 PM
Coan's Avatar
Alleged User
Where exactly is the internal clip? I have been inserting the screwdriver into the hole that is in the end of the plug and wiggling it and prying in every direction, but it just doesn't seem to want to release....
Jon
Old 08-17-2010, 08:31 PM
Unless you have a jeweler's driver, you won't catch it. Fine a little nail with a sharp point. I think you go down the narrow side, and once you hit a stop, pry up to release. I always seem to figure it out with a sharp point
Old 08-17-2010, 09:03 PM
Coan's Avatar
Alleged User
Ok I took a few pics to see if I'm doing this right.
First off, are these little plastic squares on the side of the connector the release tabs?
Here is where I'm inserting the nail/screwdriver:
And in this pic you can see that the tip of the nail is stopping on top of the little plastic square shown in the first pic:
Am I doing this all wrong? lol
Jon
Old 08-17-2010, 09:36 PM
I've always found it necessary to fiddle with the nail while pulling on the wire with slight pressure. The nail won't hold the clip by itself, as pictured. As you feel the nail push the clip, be lightly pulling on the wire. Use both hands to do it.
Old 08-17-2010, 09:39 PM
Glenn
If you can see POWER, it's there, probably need to remove a small bit of black tape and insert a bulb.
Old 08-17-2010, 10:01 PM
Coan's Avatar
Alleged User
Finally got it! Apparently I busted the plastic clip in that slot and it got jammed in there and that's why it wouldn't move. Little bit of force got it out, and inserted into pin 4. If anyone is going to attempt this in the future, those pics I took are step by step of depinning the connector. Thanks a ton NFS for your help!
I can definitely see it with a flashlight on my 97. Ironically, I just had the cluster out last week to change a gear indicator bulb and didn't even think to check for this. Doh! As far as I remember, it didn't seem blatantly obvious that any bulbs were missing though.
Jon
Old 08-17-2010, 10:14 PM
No problem, glad you finally got it
I've seen gauge packs with factory tape here or there. My hopeful guess is there is tape and no bulb, and if a Power Switch is wired, the POWER lamp will illuminate
Old 10-30-2010, 06:01 PM
Awox Awox is offline
I Just performed this mod on my 95 LS, switch is still dangling and needs to be properly mounted. But after the test drive, I would recommend this to ANYONE. It transforms the car completely in the corners and on hills and makes it so much easier to coax that oversteer out of it.
Thank you all for this post!
Old 10-31-2010, 05:55 AM
I'm glad you like it!
Most of the cars I have now are UK, same Power on demand system in the gearbox as the USA one. I find them impossibly sluggish due to the gearbox programming, not at all sporting.
Phil has done a re-programmed TCU for me. [the UK gearbox is wired differently, it's not so simple as the USA type for wiring up a permanent Power switch] Now that I am back in work again and as soon as I catch up with bills I'm going to install that and run the UK 95 car I have here.
That will be interesting to see how it goes. I'll report back in a few months when I get the time and money to proceed.
