Old 10-26-2005, 11:25 AM
hpcsvx hpcsvx is offline
cruise control button works intermittently
When i push in cc button, light sometimes comes on, sometimes doesnt. When light comes on, cc works great. If no light, no cc. How difficult is it to replace the switch? Thanks in advance.
Haven
Old 10-26-2005, 11:32 AM
pipedream's Avatar
pipedream pipedream is offline
Send a message via AIM to pipedream
No help here- But just adding, I've experienced this behavior since I first got my '92 svx... You've gotta punch in the CC a couple times to get it activate.
It barely rates as a bother in comparison to some of the **** that can go wrong on the car, so I haven't really looked into it.
I'll watch this thread though.
Old 10-26-2005, 12:11 PM
Pull the cap and try some good electrical contact cleaner.
Old 10-26-2005, 02:19 PM
This is a very common problem with the CC switch. You just have to push it until the light comes on. Its not like you are doing anything besides driving any way.
If you get a new cluster of switches, it may have the same problem. I have found that the more I use it, the more it works on the first try.
Old 10-26-2005, 02:25 PM
dcarrb dcarrb is offline
Hey, so I'm not the only one! Mine barely worked at all when I bought the car (which had been sitting on a dealer's lot for awhile), and now it works the first time, most every time. But if I don't use it for a few weeks I can count on having to press it repeatedly.
dcb
Old 10-26-2005, 02:27 PM
Like they say: "If you don't use it, you loose it !!!"
Old 10-26-2005, 04:20 PM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
The indicator light also went out on mine, and I'm too lazy to fix it, so I have to push the button, and try to set, and push the button, and try to set, and push the button, and try to set, and.... I can usually set it within a few seconds.
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 10-26-2005, 05:16 PM
immortal_suby's Avatar
Thread Killah
Push it in and hold for a little instead of a quick jab. Works for me.
Locker Link
2015 BRZ Limited 6MT
Old 10-26-2005, 06:19 PM
Steve - you should really fix Kermits light!
Old 10-27-2005, 01:55 AM
Rotorflyr's Avatar
I've found with mine that if I don't push it all the way in it engages nicely, just about the first shot every time. It's barely a bother so I haven't looked into doing anything about it, but eventually will try contact cleaner.
Im not a huge fan of cruise control anyway.......
2006 B9 Tribeca
Old 10-27-2005, 10:35 AM
how to take cap off switch?
Thanks for all the input. One reply mentioned taking the cap off and spraying with contact cleaner. How does the cap come off? Do I just pry it off with a small screwdriver? Does it then pop back on, or do you have to glue it in place.
Thanks for the help!
Haven
Old 10-27-2005, 05:01 PM
wasions's Avatar
Heheh.
Good grief, Earl. Twelve?! That's like about 20% of the viable SVX's left in the world.
Steve
Old 10-27-2005, 06:53 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
You should also check the vaccume hose under the hood of the car too. If that is leaking, cruise will not work.
Lwin M. Maung (Member # 147)
Current SVX: NONE
