Old 10-17-2005, 08:46 AM
davew833 davew833 is offline
Fans run all of the time??
My cooling fans come on when I start the car and run all of the time. Is this normal. In my other Subarus (and Hondas, Nissans, etc.) the fans didn't come on until the engine heated up.
Old 10-17-2005, 10:55 AM
svx_commuter's Avatar
Do the fans run when turn OFF the climate control?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-17-2005, 01:59 PM
How's your engine temperature sensor? That is a symptom of this dying/dead sensor.
Old 10-17-2005, 02:03 PM
Re: fans run all of the time
BOTH fans come on the minute I turn the ignition switch whether the climate control (and/or A/C) is on or not. I recently replaced the temp sensor to cure a hard start condition.
Old 10-17-2005, 03:19 PM
Try the process for clearing engine codes.
Old 10-17-2005, 07:57 PM
kuoh kuoh is offline
You might want to double check the wiring and the temp sensor itself. I think that's a failsafe when the ECU can't read the sensor.
KuoH
Old 10-17-2005, 10:03 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
My both svxes' fans won't run after I start, if the Auto Climate is off.
If the Auto Climate turns on, fans will run, if they run(most of the times
I observed), they run together.
If it's on AC, when it gets cold enough, the fans will stop for few mins.
If the engine gets hot, the fans will usually keep running or get faster
and louder if the weather gets real hot. That's my observations.
Anyone knows if the fans have variable spd? Such as Lo, Med, Hi? I just
think it shld have at least two spd, sometimes it runs fast sometimes it
runs slow....
I asked the local subaru service dept once I bought some parts. They
said both fans ran individually, it didn't make sense to me, and not similar
to the system like some hondas, toyotas...
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 10-18-2005, 05:36 AM
michael's Avatar
michael michael is offline
What Potholes ???
Just curious, Does your speedometer work?
Wanted: Steering Wheel
Old 10-19-2005, 12:31 PM
runs slow....
The FSM states that the fans have 4 settings: off, low, med, high.
I've never seen only 1 fan running.
Old 10-19-2005, 05:52 PM
Fan Follow-up
I disconnected the battery overnight to clear the ECU codes and still both fans come on when I turn the key. I'm wondering if the fans quit working when the temp sensor (which I replaced) went out and the previous owner just hot-wired them to be ON all of the time rather than just fixing the temp sensor. I've noticed the fans change speed on my other (dead now) SVX, but these fans seem to be on "high" constantly. Guess I'll inspect the wiring next.
Old 10-19-2005, 06:03 PM
Try the blue wire method. It should take 5 minutes or less.
Old 10-20-2005, 02:20 AM
SSSVX's Avatar
Wonderful. Finally, someone can answer this question to me. It makes sense to me now with my observations. SVX is a high-tech car, it shld have variable spd on the fans.
Me too. I have never seen or felt only 1 fan running. I think the subaru service dept locally told me the wrong thing.
-SSSVX
Old 10-20-2005, 06:58 AM
You may have never seen it, but it does happen under normal circumstances, especially in cold weather. When the climate control is off, only one of the fans will run if the engine is cool or warm. When the engine gets hotter, both fans will run. When the climate control is on, one of the fans is always running.
KuoH
Old 10-20-2005, 11:36 AM
You've seen it? I've played with the climate controls and have never seen just one fan operating.
Old 10-20-2005, 12:37 PM
dcarrb dcarrb is offline
KuoH
I'm (almost) positive this is not the case with mine. I never turn-off the climate control, and at idle with a cool engine on a hot day, neither of the fans run until she warms-up, then both kick-on at once.
This is getting confusing...
dcb
