Old 10-13-2005, 05:43 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Question annoying high idle
when my car is fuly warmed up and i let it idle for more than 2 or 3 minutes the idle will go up to about 950rpm's. it just started this about a month ago and now it's happening more frequently.the idle won't go back down until i shut the car off and restart it and it will just do it again if i don't get moving within a minute of restarting it. i want to try to figure it out and make sure it isn't anything performance hampering as i'm hitting the track on tuesday and really need this thing running perfect.
Also, i noticed there is now sort of a thumping coming from the engine that wasn't there before i put the new sprocket and crank pulley on it. i can only seem to hear it inside the car though. i also still have the cold knock or tap i've talked about before on here, but it still goes away when it warms up. just hope nothing goes kablooey on tuesday but if it does i guess i'll fix it one way or another like always. damn car addictions! we need to start an svx anonomous class for all of us addicts
Jason
Old 10-13-2005, 10:04 AM
svx_commuter's Avatar
Do you just hear that thumping noise at low speed idle? I have noticed a thump in both my engines. That's good for 160k miles. I have also heard 'THE THUMP" in other SVX engines. I don't hear it when the engine is working harder and loaded up. It does not appear to BE anything to worry about. Is it possible that it was there before and you didn't notice it?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-13-2005, 02:46 PM
Manarius's Avatar
Manarius Manarius is offline
My car runs high idle when cold..I can make it go away with a tap of the gas pedal when warm. Perhaps your car is just feeling the effect of the cold weather.
-Jason
-Obi Wan Kenobi
Old 10-13-2005, 03:19 PM
Budfreak's Avatar
Banned
i definitely would have noticed the thumping before as i always listen to my car and very rarely ever listen to the radio or anything. it only does it when idling warmed up. i'm not to worried about it, i just wanted to know what would cause it all of a sudden.
Old 10-13-2005, 03:28 PM
Budfreak's Avatar
Banned
i don't think so because i drove it all last winter with no such thing happening and it's not even that cold out yet. it only happens when warmed up and it idles for more than a 2 or 3 minutes like at a drive thru or something. it runs as normal any other time though. i got my stupid "almost warmed up" check engine light again today too. it keeps throwing a code 32 but it rarely does it any time but when it's almost warmed up and under load and usually goes right back off within a minute. there was someone else on here with the same exact ce light problem. i'm not sure if an answer was ever found or not.
Old 10-13-2005, 05:30 PM
Manarius's Avatar
Reset the ECU and see if it still has that code...maybe something is broke...
-Jason
-Obi Wan Kenobi
Old 11-04-2005, 05:19 PM
jb21585's Avatar
jb21585 jb21585 is offline
the exact same idle issue your having I am having also. Sometimes it doesn't happen, but I don't think its anything bad, maybe a bad or going bad TPS.
1995 Claret SVX LS-i
1985 Toyota Tercel SR5 4wd wagon
Old 11-04-2005, 10:47 PM
Budfreak's Avatar
Banned
i've tested my tps by hooking up my meter and slowly moving the throttle. it looked very smooth, but i've noticed i only get my 2-3 flair on my tranny when i have the throttle in a cretain range so i'm starting to suspect it. i'll look into further in a few days.
