Old 10-11-2005, 10:54 AM
1992SVX 1992SVX is offline
power steering return line
i just got finished replaceing my my return line. to stop the smoking from the leaking hose. and it still leaks onto the exhaust
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 10-11-2005, 12:47 PM
ilsegretosvx
Did you get a new one or used? They tend to leak from the crimp if used.
Old 10-11-2005, 03:31 PM
no it is brand new
Stage1 Shift Kit
4.44 gears
Old 10-11-2005, 04:46 PM
mbtoloczko's Avatar
sans SVX
There are two return lines. One from the steering rack to the PS fluid cooler. (There actually is a cooler. It consists of a single u pipe.) The other return line goes from the cooler to the PS pump reservior. If you only replaced the line between the cooler and the PS pump reservior, then maybe the return line from the rack to the cooler is leaking badly. Might also be that the high pressure outlet on the PS pump is leaking. Fluid could leak down the front of the engine and onto the exhauset (and everything else under the car as the wind sprays it around).
Mychailo
Visit my locker
Old 10-11-2005, 04:51 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Has it had time to burn off all the fluid thats already saturated your exhaust?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-11-2005, 05:32 PM
it has had time to burn off. about 4 hours of driving. it is the rubber hose from rack to the cooler. it is that one foot section of rubber hose above the exhaust. it was dry rotted and had holes in it
Stage1 Shift Kit
4.44 gears
Old 10-11-2005, 06:50 PM
clarkerussell
Should you use OEM hoses from Subaru, or are they universal? Thanks.
Old 10-11-2005, 06:54 PM
Universal hose is fine for the low pressure return lines.
Old 10-11-2005, 07:44 PM
mbtoloczko's Avatar
sans SVX
Universal hose is fine as long as its rated for ATF.
Mychailo
Visit my locker
Old 10-11-2005, 07:49 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
Agree. I used universal ATF hose.
Old 10-11-2005, 09:37 PM
i used the universial atf hose
Stage1 Shift Kit
4.44 gears
Old 10-12-2005, 03:08 PM
clarkerussell
Do they just use a regular hose clamp to attach to the fittings?
Old 10-12-2005, 03:16 PM
I used the generic screw/cam style hose clamps with no problems on generic hose I bought at PepBoy's Automotive.
Robert
Old 10-13-2005, 06:45 AM
dcarrb dcarrb is offline
I used off-the-spool ATF-rated hose and generic screw clamps. Approaching two years with no troubles.
dcb
Old 08-04-2007, 09:39 PM
disbo disbo is offline
Return line for Power Steering question
Hello all,
I have had a slow leak on the drivers side going down on the the manifolds and steaming up. I have used the seach function and think this is the return line on my 94. I looked at the high press line that goes back on the passengers side and it looks fine. I got up under the car and saw three steel lines going along the steering rack but dont see any rubber lines.
Could anyone point out where this line is. I have the new line I got at Advance Auto since Im tired of putting in PS fluid every week or so.
Here are some picture of the left side of the steering assembly where I dont see any rubber hoses? Also, there is a shot of the damage in rust where the leaks from the PS have corroded items.
thanks Chris
