Old 09-26-2005, 08:08 PM
88GL10T
EG33 Q's
I was wanting to know a few things about the EG33. are all EG33's closed deck. are all DOHC. do all have 6 exhaust ports. do all have a 230hp stock rating. is there a stronger engine year. do any have a better thrust bearing. different compression ratios? are all 4 valves per cyl? what is a good price for a used but running EG33? i found one for $750 for engine and ecu seems a bit pricey. what tranny can i bolt it up to any ej series what about an adaptor plate for ea82 series 5mt? any info would help
Old 09-26-2005, 08:19 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
All EG33s are identical and, unless I'm mistaken, only came in the SVX. All are open deck engines.
Old 09-26-2005, 08:32 PM
Beav - you are right. Subaru told us at the 10th Anniversary meet in ID, that the only car they put that engine in was the SVX. It was too expensive to put into any other car that they have produced.
Old 09-26-2005, 09:04 PM
88GL10T
I thought that the EG33 was a closed deck block
Old 09-26-2005, 10:19 PM
Beav's Avatar
Not as old as Randy
Nope. Search through this site and you should find a couple pics with the heads off.
Old 09-27-2005, 03:15 PM
wawazat??'s Avatar
Yeah, I'm still around
Originally Posted by 88GL10T
I was wanting to know a few things about the EG33. are all EG33's closed deck.all are open deck
are all DOHC.all are DOHC
do all have 6 exhaust ports. all have 6 ports (unlike the ER27 and early EZ30)
do all have a 230hp stock rating. yes
is there a stronger engine year. No
do any have a better thrust bearing. No
different compression ratios? all the same
are all 4 valves per cyl? Yes
what is a good price for a used but running EG33? i found one for $750 for engine and ecu seems a bit pricey. This is a good price with the ECU depending upon miles and condition of course
Any trans the bolts to an EJ series Subaru motor will bolt to an EG33. I don't believe that there are adapter plates for EA series transmissions and I alos doubt that these early boxes can handle the torque output of the EG33.
Best of luck with you project.
Todd
Down to none
