Old 09-24-2005, 11:36 AM
Joe 90's Avatar
Joe 90 Joe 90 is offline
Canadian eh!
Replacing fuel lines...Help!
Hi,
Has anyone attempted to replace the fuel lines? How hard is it?
My lines are corroded and leaking near the driver's side rear wheel. I've repaired two lines with hoses about 2 years ago... But they started to leak again due to more corrosion... I guess it would be time to replace them now. I looked at the parts catalog and it looks like they are one piece front to back! Is that so? Do I have to dismantle half the car to do this job? Any input would be greatly appreciated!
Best regards
1994 Dark Teal SVX With real HID & Small Car Shift Kit (310000 km and counting)
Old 09-25-2005, 09:34 PM
svxstarship svxstarship is offline
I cut the leaking one from near the rubber grommet under to rear seat and replaced it with rubber fuel line and clamps. Not exactly the ultimate solution but it worked. Used a brake line cutting tool on the pipe. Don't you just love that Montreal salt? What year is your svx?
Old 09-25-2005, 09:36 PM
Ooops it's a 94. Just noticed.
Old 09-26-2005, 02:31 PM
Joe 90's Avatar
Canadian eh!
Well, I did that rubber hose repair on both lines already.... I guess corrosion just chewed a bit more of the lines..... I'm considering replacing them both at this point....
Any suggestions?
Old 09-26-2005, 04:21 PM
Aren't there 3 lines. Maybe you missed the leaking one. Longer hose? Otherwise you would have to drop the tank I believe to replace the lines. I have come close to actually dropping the tank when replacing the rear metal brake lines. Speaking of rear metal brake lines... if your fuel lines are rusted you can bet the brake lines that run behind the tank are as well!! So if you do end up dropping the tank be sure to replace these.
1999 Audi A8. No more SVX's for now.
Old 09-27-2005, 10:56 AM
Joe 90's Avatar
Canadian eh!
Thanks for the input.... Not exactly what I wanted to hear....
If I drop the tank, I make sure to check the brake lines as well...
