Old 09-20-2005, 10:40 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Question alarm led rating
i need to know the ratings on the led bulb for the security switch. the guy at radio shack said i need to know or i could screw up the system. is he full of crap or does someone have this info.?i need to know so i can get the led today. thanks, Jason
Old 09-20-2005, 02:27 PM
It's not an LED (but then again my car doesn't have that button).
Search the forum for "radio shack" and you'll get the exact part number you're looking for.
Old 09-20-2005, 07:42 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Actually, for the security system it is an LED that flashes red when active.
I don't know the voltage, but you could use a meter to check it.
As for wrecking the alarm with the wrong LED, I guess it is possible, but I would think that the LED would fry before the alarm.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 09-21-2005, 01:24 AM
Budfreak's Avatar
Banned
Question
Doug
how do i check it with the meter? i checked the switch and one terminal was 12 volt constant and the other was pulsing .5 volts on my meter every 2 seconds.
Old 09-21-2005, 10:49 AM
Thanks for the correction Doug!
Eventually I'll be looking into getting a security system put in my car.
Old 09-21-2005, 01:36 PM
mohrds's Avatar
My hunch is that the .5 pulse is the correct one.
I don't remember from the last time I had that switch apart, but could it be possible that the LED is in backwords? If it is a twist in, you may want to remove it twist it 180 degrees and reinstall and see if it works again.
1994 LSi (4/93)
2000 Ford Excursion
Old 09-21-2005, 01:38 PM
mohrds's Avatar
The green light on the Driver's side window switch cluster is also an LED as are the exterior keyhole illumination
and so are all my tail lights
1994 LSi (4/93)
2000 Ford Excursion
Old 09-21-2005, 02:10 PM
Budfreak's Avatar
Banned
Cool
i took care of it today. blink blink blink blink
it's a 3mm t1 red led radio shack part no. 2760026
Old 09-21-2005, 06:15 PM
Now you're just showing off!
