Old 10-30-2013, 11:34 AM
theflystyle's Avatar
Re: Where do I put Seafoam?
Originally Posted by Lookin4SVX View Post
SoCal, you mean here?
Any tips on getting those vacuum lines off if they are stubbornly stuck to the TB?
Also would splitting the procedure between each side of the TB vacuum lines (pictured above) be any better than just dumping into one?
Thanks
1994 SVX LSi
2008 Legacy 3.0R
Old 10-30-2013, 10:14 PM
intelisevil's Avatar
<<<Alcyone
Try getting some needle nose pliers in there. Start at the bottom (end of the hose) and rotate the hose a little, move up some and repeat. Keep moving up until you find the top of the metal tube. Once it's loose up to the end of the metal tube you should be able to work it off without causing any damage. If the vacuum hose cracks, it was time to be replaced anyways . . .
If you only use one hose, you'll only get half of the engine. It's pretty much two independent air intakes beyond that point. I'm not looking at my engine right now but that's what I remember.
Go slow with removing the vacuum lines and you might want to have someone to blip the throttle for you once you start sucking up the Sea Foam.
If you live in town it's best to do it when it's dark so the neighbors can't see the smoke!
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 10-31-2013, 09:34 AM
Uncamitzi's Avatar
Member #447
I've used Seafoam in my 850GL motorcycle engine with great results. I will keep it in mind as I progress with my repairs..
Mitch Hansen
"uncamitzi"
This is a Dark Ride
Old 08-15-2014, 06:13 AM
I know its an old thread but I wanted to post my results from the seafoam treatment.
I put half a can through each side of the TB while the car was parked and of course running. I was a little shocked with the lack of buildup being cleared. I then took the car out and for the next few miles it was like the back of my car was on fire. The amount of smoke was insane and I am glad I did this in the middle of nowhere without other cars.
The car definitely is running better. I wouldnt hesitate to say it was never done on the car before. I think I may do another pass through to see if anything was left.
1994 SVX LSi
2008 Legacy 3.0R
