Old 11-14-2014, 10:54 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
After much research and opinion polls I ordered an Optima Yellow top over a Red top based on the fact that my sound system and electornic gadgetry is pretty crazy! The 3 South Dakota winters took their toll on my good ol' Super start. (California battery which is rated at 500 CCA.) Anytime it gets below 30 degrees the car won't start, heck it doesn't even turn over, and so far that has been the past ohh... idk... 8 days
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 11-17-2014, 12:13 PM
i love my yellow top. i put it in then didn't drive the car for a week and accidentally left the dome light on. it still started right up.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1956 Plymouth Belvedere - Daisy
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 11-23-2014, 03:08 AM
steamer99's Avatar
steamer99 steamer99 is offline
Took her on a 300 mile trip, she performed flawlessly, what a great highway car.
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 11-23-2014, 06:16 AM
michael's Avatar
michael michael is offline
What Potholes ???
New Bosch Evolution Wipers small, but something.
Wanted: Steering Wheel
Old 11-23-2014, 09:06 AM
gwynethh's Avatar
gwynethh gwynethh is offline
More bench work on the JDM to USDM HVAC controller. Recover from a pre-winter head cold.
"Peace is the flower of justice."
Old 11-23-2014, 09:38 AM
michael's Avatar
What Potholes ???
Update: It's raining and they work great.
Old 11-23-2014, 03:57 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
I took off my rear spoiler so i can repaint it, so it will look proper again.
Also need to figure out which other coil is going bad. I replaced one which was totally dead, must be another one that is on the way out.
Also...working up the price list for Phenolic spacers check the mod mania post if interested.
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 11-24-2014, 05:28 PM
Gamesy's Avatar
Gamesy Gamesy is offline
winter mode!
installed bra and put on winters
Old 11-24-2014, 05:46 PM
Put snows on the Accord Coupe and winter wheels and tires on the SVX ,wish I had my car lift already. . Ready for snow on Wed. 66 deg today and tomorrow. Looking at 6" of the white stuff Wed. Morning.
Old 11-26-2014, 05:18 AM
Left work early yesterday to put my snow tires on. I'm not used to snow this early and I'll be needing them today.
Old 11-28-2014, 07:52 PM
Chucksta Chucksta is offline
97 SVX
Installed Re-built trans from my donor car.
replaced rear main crank seal.
re - sealed plastic observation port at back of engine.
swapped out the summer 18s' for the snows on 17s'
new trans filter
10 liters Mobil1 full synthetic trans fluid.
Total, all in..$670.00 and a box of Krispy Kreme.
So That's what a fresh trans feels like.... Damn!!
02 WRX
4 rotors ( anodized ), slotted and drilled, semi-metallic pads
$180.00
Oil change ( full synthetic),
extract broken caliper mounting bolt, free up two seized sliders,
machine rear rotor e- brake lip. so it will turn when you tighten the wheel lugs
put on the snows... sigh ...
$240.00
Been, well, a long time since I've ran semi metallic pads.. forgot how much I like the feel of them, I'll put up with the black dust and reduced lifespan just for the way they feel.
Old 12-08-2014, 11:15 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Posted picutres of my new Subaru badge of ownership.
https://www.dropbox.com/s/1gyzbybarz...20005.jpg?dl=0
https://www.dropbox.com/s/xdf5srdgun...20004.jpg?dl=0
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 12-14-2014, 07:22 PM
I decided it was time to get my SVX a new cheap supplemental daily driver.
Last time I just grabbed a base model legacy lease, but I did not want to lease again this time.
Subaru's here were like $21K for an Impreza, $23k for a Legacy, which is more than I want to spend on a second car.
I didn't really need AWD on it, just something cheap on fuel, not a hatchback, and not terrible to drive...
So I went with a 2014 Mazda3 iSport 2.0L 6-speed manual:
For what it cost me, it is actually a pretty fun car to toss around these twisty mountain roads.
It reminds me a lot of driving my 2001 Impreza 2.5 RS coupe.
This is my first non Subaru in 14 years, will see how this goes...
Old 12-14-2014, 07:27 PM
bheinen74 bheinen74 is offline
my 97 SVX got new rear bearings both left and right..did the job myself with my fathers assistance, used his press. Car has 66k
The old bearings, had grease, but the rollers showed heat signs, they were noisy. I think they were redone at some point prior to me getting the car, and i think they didn't use the right grease maybe.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 12-15-2014, 06:13 AM
gwynethh's Avatar
Some owners have noted that after repeated failure they also replaced the hubs (which may have distorted from bearing over heating). Something to keep in mind for the future.
