Old 10-29-2005, 02:57 PM
kuoh kuoh is offline
A real remote trunk release
I was fixing up the lower trunk trim piece and thought I'd take the opportunity to snap a few shots of the remote trunk release solenoid. I installed this 8 or 9 years ago when I replaced the OEM alarm with one that had more channels and sensors. The solenoid is attached to the right rear trunk cover support with a couple of pieces of metal strips. Not the prettiest mount, but it was what I had on hand and I didn't feel like drilling any unnecessary holes for a better mount. The pull cable is attached to the same lever as the factory remote release cable. It's handy to be able to open the trunk without having to open the driver's door too.
KuoH
Old 10-29-2005, 05:24 PM
What did the remote come out of?
Old 10-29-2005, 05:28 PM
Come again?
KuoH
Old 10-29-2005, 09:40 PM
Ok, maybe I need to rephrase this. What brand of remote is it? I thought you may have taken it out of another car.
Old 10-29-2005, 10:02 PM
It's an Alpine SEC-8052 security system with proximity sensing, paging and 3 remote controlled outputs. I've got it wired so I can release the trunk, remote start, mute the stereo, and disable the shock sensor for those really stormy nights. The trunk release solenoid is just a generic model made by DEI.
KuoH
Old 11-15-2005, 02:48 PM
mbtoloczko's Avatar
sans SVX
Kuoh,
What wire did you use to power the solenoid? Same one for the alarm control unit?
Mychailo
Visit my locker
Old 11-15-2005, 06:48 PM
I had already ran heavy gauge wire to the trunk for the amps, so I tapped power from there. If you just have stock trunk wiring, then you could probably pull power from the brake light tester or the power antenna.
KuoH
Old 11-15-2005, 08:58 PM
mbtoloczko's Avatar
sans SVX
KuoH
Are either/both of those wires hot when the car is turned off?
Mychailo
Visit my locker
Old 11-16-2005, 07:59 PM
orangeSVX
Thumbs up
Hey, I have the same on my SVX, remove that bracket and simply shove the solenoid through the bracket on the body and put a pipe clamp on the end of it. It works great! just the bare solenoid, it'll clean up what u got goin' on there...
Old 11-16-2005, 09:26 PM
mbtoloczko's Avatar
sans SVX
What did you use to power the solenoid?
Mychailo
Visit my locker
Old 11-17-2005, 10:20 AM
Earthworm's Avatar
Meow!
Welcome to the site! Which Ontario are you in?
Old 11-20-2005, 12:36 PM
orangeSVX
Cool
Hey thanks!! from Guelph, Ontario Canada!!
i tapped into my positive line right from the battery (same as Kuoh from my amp for sub woofer) hooked it up to a relay and controled by an alpine alarm/remote..maybe the same modal as Kuohs! lol
