Old 10-30-2005, 01:48 PM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Speedometer Problem and Check Engine Light
My speedometer does not work on my 1994 SVX and I was wondering if there is a cheap place to take it or if anyone has any info. on how to fix it yourself. Also, is the speedometer mechanical or electrical? Any help would be appreciated.
Another problem with my car is the Check Engine light turns on and off randomly. I do not know if it is a bad sensor or not. There seems to be no mechanical problems with my car and I notice it usually turns on when I go up a slight hill. Anyone know the reason for this?
Old 10-30-2005, 03:26 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
The speedometer is electrical which runs off speed sensor 2. It's expensive. look here: http://www.subaruparts.com/diag/?mod...category=835-A
But that would be the good news. If it is the plastic gear in the front dif that the sensor runs off of, then the cost skyrockets to a thousand, due to they have to pull the transmission to replace it.
Here's all the technicals: http://www.subaru-svx.net/photos/user.php?How-To|14246 (Copy and paste into your address block.)
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 10-30-2005, 03:33 PM
As for your check engine light, go here to Earthworm territory: http://www.svx-iw.com/
Do a search on "codes", and it will give you choices. The one you are concerned with now, is "engine trouble codes" but read them all to learn about next time.
Welcome to the site!!!
Robert
