Old 09-13-2005, 08:10 PM
The Molinator
Oil Leaking...........stillllllll!!!!!!!
After my $3000 (+) head gasket job, I just noticed I'm getting oil leaking (again) from my engine....onto the driver's side catalytic convertor (sometimes creating a minor smoke billowing situation!).......YIKES! I replaced every gasket and seal I could think of...evidently I overlooked at least ONE! Seems to be coming from rear driver side of engine...???? Is there anything in that area that could explain such a mild to moderate oil leak (which sometimes ends up dripping onto the top of the driver's side catalytic convertor...causing ANNOYING SMOKE!) [It's dripping enough so that in 2 weeks, I've accumulated a 5 to 6 inch diameter oil spot in my garage.]
Please speculate on the source of this leak.....
THANKS!
Jim
Old 09-13-2005, 09:01 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Are you sure it is oil and not trans fluid? Mine had a mild leak in that area which progressed into a severe leak. There are two lines for trans fluid to travel to the cooler and back. Between the engine and transmission there are hoses and if the clamps come loose they will leak ATF all over the drivers side cat.
These clamps can be a pain to get to, the one that was causing most of my problems couldn't be seen, I had to find and tighten it "blindly"
If it is oil though, my guess would be valve cover gaskets...
Old 09-14-2005, 08:01 PM
The Molinator
Leak!
I'LL CHECK!......Thanks!
Jim
Old 09-14-2005, 08:57 PM
Manarius's Avatar
Manarius Manarius is offline
Rear Cam Seal. My car did the same thing. I switched from 10-30 dino oil to 20-50 dino oil and the leak basically disappeared.
-Jason
-Obi Wan Kenobi
Old 09-15-2005, 06:59 AM
Jayahalasi
Is it really wise to put heavier oil like that into our cars?
ohh..... well he has a legacy.. but still.
Old 09-15-2005, 07:46 AM
immortal_suby's Avatar
Thread Killah
Rear cam seal? Not likely. We don't have one.
Only source of oil leaks on the rear of the engine is the rear main seal (crank seal).
In any event it is better to fix the leaks than put in a heavier weight oil.
Locker Link
2015 BRZ Limited 6MT
Old 09-15-2005, 08:54 AM
1992SVX 1992SVX is offline
sorry do not mean to tread jack. i justreplaced my valve cover gaskets. and there is still something leaking from the back of the motor. i get smoke at stop lights from rear of the motor
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 09-15-2005, 09:26 AM
Thread Killah
If it is oil it could be the rear main seal.
If it is tranny fluid it could be the power steering lines or the rack leaking.
Also - front main seals or cam seals can leak out the timing cover, then while driving the wind blows it back onto the exhaust and it appears to be coming from the back of the engine.
Locker Link
Old 09-15-2005, 07:56 PM
i know it is not the rear main seal because i just got my transmisson replaced. by svxfiles. and he would have told me if there was anything wrong.
i think it is the rack or power steering lines. because even in traffic sitting in one spot it will will start smoking untill i turn the car off
Stage1 Shift Kit
4.44 gears
Old 09-16-2005, 02:05 AM
The Molinator
Leaky
Be sure to check the Power Steering fluid reservoir to verify the loss of fluid! My mechanic told me he was gonna replace the Rack & Pinion, convinced that it was the source of my "oil lleak". I decided to watch the power steering fluid level....only to find IT NEVER DID GO DOWN OR LOSE ANY power steering fluid level!
Jim
Old 09-16-2005, 10:48 AM
sometimes it goes down then it will full again. both times the car sitting for 5-6 hours before being checked
Stage1 Shift Kit
4.44 gears
Old 10-20-2005, 08:02 PM
The Molinator
No Mas!
Thanks for the input guys...and the idea Dave! I decided to try tightening the clamps on the short connector tubes you mentioned for the ATF fluid going to and from the ATF cooler in the bottom of the radiator. NO MORE LEAK! THANKS!
I wanted to follow up with this question for your sakes....because I can't stand a thread that fizzles out in the end .....with no resolution...???
THANKS AGAIN!
Jim
