Old 10-07-2005, 09:42 AM
djsiva's Avatar
djsiva djsiva is offline
Send a message via AIM to djsiva
tire size help
I've got a set of Lexus IS300 Sport Design wheels (17x7) on my car with the factory Lexus size tire of 215/45/17 on them. I want to change tires to a wider tire and I'm not sure what is best to get or what will even fit. I'm thinking 235/45 or 235/40. Does anybody know if these will fit without rubbing or harming something else?
Thanks,
Nate
Old 10-07-2005, 09:44 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
What's the offset on the IS300 wheels?
2006 Steel Gray WRX TR (sold)
Old 10-07-2005, 11:45 PM
djsiva's Avatar
chike, I'm looking for the offset of the IS wheels but haven't been able to find it. I'll let you know as soon as I do. Thanks for your help.
Nate
Old 10-07-2005, 11:59 PM
djsiva's Avatar
Nate
Old 10-08-2005, 06:41 AM
wawazat??'s Avatar
Yeah, I'm still around
Watch the wheel width as that's more important to fitting a wider tire than the offset. I believe the IS uses a 7" wide wheel with a 35mm offset.
Todd
Down to none
Old 10-08-2005, 11:43 PM
djsiva's Avatar
chike...
Hey, the wheel is a 17x7 50mm offset. Do you think I could fit 235/40 or 235/45's on there and not rub in the SVX? I know a 235 will fit the wheel because a couple people at the dealership I work at have a staggered wheel setup on their IS300's using 235's in the rear.
Thanks
Nate
Old 10-09-2005, 12:04 AM
mbtoloczko's Avatar
sans SVX
235/45-17 is a bit wide for a 17x7" rim. I wouldn't run anything wider than a 225/45-17.
Mychailo
Visit my locker
Old 10-09-2005, 08:06 AM
Chiketkd's Avatar
Agreed. 225/45 should be the largest you run on a 7" wide wheel. The offset is good though.
Old 10-09-2005, 06:08 PM
wawazat??'s Avatar
Tirerack lists manufacturers specifications for the tire they sell that give you a recommended rim width range for each tire size. Could be helpful in your hunt.
Todd
Down to none
