Old 11-06-2002, 09:18 AM
Breck SVX
Alternator
So i got an alternator from Napa, took my old one out and pretty much put the new one in...The problem i'm having (i dont have a hayes manual or anything) is that i cant get the lower left hand screw in...it doesn't seem to line up well. Is there some sort of tensioner to loosen the slack on the belt? Theres that diaganol screw on the lower left hand side of the alternator under the power steering pump; is that a tensioner for the belt?
any help would be appreciated.
thanks
-Alex
Old 11-06-2002, 09:27 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Alternator
thanks
-Alex
If you're talking about this screw: http://www.subaru-svx.net/photos/fil...ubjay/1818.jpg
Yes, it's to adjust belt tension.
Randy Johnson
Mike Davis -- at Reading VI
Old 11-06-2002, 09:32 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: Alternator
thanks
-Alex
You need to install the alternator before installing the belt. The tensioner has a pulley located just under and to the left of the alternator. First, loosen the 12mm pulley nut, then loosen the tensioner bolt (see Randy's picture) until the belt will slip over all the pulleys, then tighten tensioner and finally tighten the pulley nut.
DOug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 11-06-2002, 09:46 AM
Breck SVX
what exactly do you mean by the 12mm pulley nut?
Old 11-06-2002, 10:05 AM
mohrds's Avatar
If you follow the belt to the idle pulley, there is a 12mm nut on the front, center of the pulley itself that holds the tensioner from moving.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 11-06-2002, 10:12 AM
Breck SVX
so that nut on the center of that small pulley loosens...or do you just hold it while loosening the tension? thanks for your help
-Alex
Old 11-06-2002, 10:28 AM
mohrds's Avatar
-Alex
I loosen it about a full turn when I remove or install the belt.
The tensioner bolt requires about 10 full turns to get enough slack to slip the belt on.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 11-07-2002, 08:35 AM
Breck SVX
yeah, so i feel like an idiot. I tired doing it two nights ago with no idea that i had to loosen that pulley, it took me 4 hours and i got nowhere. Last night i went at it again with the information you gave me and i took all of 10 minutes to finish it up.
thanks again
-Alex
Old 11-07-2002, 12:47 PM
Aredubjay's Avatar
thanks again
-Alex
You've just learned the TRUE value of the Network. And you thought we were just a bunch of idiots that like to talk about goofy stuff.
Randy Johnson
Old 11-07-2002, 03:07 PM
mohrds's Avatar
Well, we are that and a lot more
Doug
1994 LSi (4/93)
2000 Ford Excursion
