Old 10-12-2002, 01:34 PM
rayford rayford is offline
Send a message via Yahoo to rayford
need to find tach wire for remote start
I have two problems with installing the commando remote start/keyless entry system : First I need to find a place to hook the tach wire from the remote unit, and the wiring diagram I got with it says it is a yellow wire at the ecu or dash tach, well I can't even see the tach from under the dash and I don't want to mess with the wires on the ecu, besides there looks to be at least 4 yellow wires going into it,, the other option with this unit is to wrap the tach wire around a spark plug wire, and since they aren't like normal sparkplug wires , that doesn't work,, does anyone have any easy way to do this??
Second problem is the door locks.. they said that it is a negative pulse system and I didn't need the relay, well I connected the wires in the drivers kick panel and nothing happens. I kind of have my doubts as to whether the wiring diagram they sent is exactly correct anywary , because the wire they said to use for the brake light was wrong, I finely found the right one, and that seems to work ok....... the reason I need the tach wire hooked up is it starts but only runs a few seconds and dies then restarts and dies and once in a while it will stay running. so thanks in advance for any help you might give on these two issues..
Vernon
Old 10-12-2002, 04:35 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Try going to http://www.bulldogsecurity.com/wires...Wiring+Details and see if it's the same schematic. You may have issues with the factory alarm module when it comes to the door locks. I just double-face taped my remote to the OEM remote. The Bulldog unit (available at Sam's, etc. - around $50) doesn't require the tach signal (you can use it if you want to though) and mine works flawlessly.
Old 10-12-2002, 04:50 PM
Beav. thanks for the address. they have the same color codes as the Commando site did, maybe they are getting them from the same source. and I found out that they aren't exactly right on everything, the brake light wire isn't white / green as is shown, I can't remember for sure but I think it is really white/red.
I thought about using both remotes. but my origional one is only good for a few feet and the commando one is good to about 800 feet..
Vernon.
