Old 04-07-2007, 05:20 PM
trickynicky trickynicky is offline
Weird Front Wiper Problem
When in "Summer Mode" my front wipers have a hesitation when they are fully extended. This ONLY happens when you shut the wipers off and they are on the last cycle before they stop. You can turn the wipers on full speed and they work perfectly with no hesitation, but as soon as you switch them off the wiper basically pauses in the fully extended position for a brief moment and a slight binding noise can be heard. Also, to make this even weirder, when switched into "Winter Mode" this problem goes away and the wipers work normally. Because of this it seems unlikely that this is a mechanical problem, and leads me to think the wiper control module has gone bad. However, because the module is $130 I would greatly appreciate anyones input, as going and buying the part and then still having the problem won't make me happy.
Since my description of the problem might not be perfectly clear, I have included a movie of the wiper problem that can be seen here. (It's a 10MB file, so 56k people be patient )
Old 04-07-2007, 06:03 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
I'm having trouble opening your file so I'm not positive - but how long has it being doing this? Meaning was it working correctly before and now it's doing something strange?
In summer mode the wipers do a strange manuever related to "parking" at the lower position on the cowling when you turn them off. Of course when in winter mode they don't park lower so there is no need for it. I'm suspecting what you are seeing is normal although I can't explain the binding noise you mentioned.
It would be easy to see if I could just open that file
OK...got it to open....I'm not seeing anything wrong there....
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 04-08-2007, 01:18 AM
I watched it and I don't see anything wrong. Maybe I need to see more.
Old 04-08-2007, 07:45 AM
Darren's Avatar
Darren Darren is offline
Hiya,
Mine do the same thing, either if you use the single wipe or on slow intermittant or when you turn then off, they pause for a second in the full sweep position before lowering back down.
I appear to have a slight amount of play so presume its just a delay taking up the play at slow motor speed. Everything still works as it should & its not my main car so I dont see it as a problem at the moment, might change a few little parts and shims and see how it goes.
Darren
11/94 SVX Alcyone, Mica Black, VL Spec 4WS, 71K Miles, 1 owner from new & was part of a private car collection in Japan.
Nissan R34 Skyline Stagea
91 Lotus Elan SE Turbo
1966 MGB Roadster, Tarten Red, Wire Wheels, Leather, 23K miles from new
You can tell the men from the boys from the speed of their toys.
Old 04-08-2007, 01:53 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Perfectly normal. I think they all do that.
Old 04-10-2007, 03:34 PM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
I agree with budfreak. I've only had my SVX a little over ayear, but its had this "problem" if you want to call it ever since I bought it, but it hasn't gotten worse and never caused me any trouble so I wouldn't worry about it
Old 04-10-2007, 06:55 PM
kwren's Avatar
kwren kwren is offline
is normal
that is the way they made them.
Old 04-10-2007, 07:33 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
It happens on mine, too. It feels so clunky! Alas...
Old 04-10-2007, 09:15 PM
Within the wiper motor assembly there are two limit switches. It would appear certain that each is set to operate at the two selectable park positions. Faulty operation in this area could produce the symptoms as recorded here.
Old 04-11-2007, 06:10 AM
dcarrb dcarrb is offline
I'll chime-in with those who say this is perfectly normal. Mine behave the same and I've never before given it a second thought.
dcb
Old 04-11-2007, 07:01 AM
RSVX RSVX is offline
Network Design Administrator
dcb
Quoted For Truth
Life is a game. Play to win.
