Old 10-31-2018, 02:58 PM
svxnavyvet svxnavyvet is offline
Case studs
Hase anyone use case studs and what ones have you used?
Old 10-31-2018, 09:14 PM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Re: Case studs
Is Case a brand of head studs? I haven't...
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-31-2018, 10:41 PM
Re: Case studs
Its case studs not head studs to put the 2 halves of the case together.
Old 11-01-2018, 09:16 AM
SoobCrazy SoobCrazy is offline
SVX n00b
Re: Case studs
I don't know about the EG33 specifically, but common wisdom is that changing from head bolts to head studs is what really needs to be done (that and adding extra dowels between the case halves).
Aftermarket case bolts are a waste of money on Subaru engines, the OEM bolts never fail.
Old 03-12-2019, 06:24 PM
tom00799's Avatar
tom00799 tom00799 is offline
Re: Case studs
I'm having a block sleeved by Dan Benson (yes I'm back in the game after ten years). He required ARP case bolts so that tells me they are indicated for high horsepower applications. ARP does not have a kit specific to the SVX engine. You need to get kit number 260-5401 and buy additional bolts from ARP. Buy the kit from a retailer like Summit because ARP charges full retail. You will need four additional long main bolts and two of the smaller case bolts which ARP will sell individually. I pulled up the PDF from the install instructions for the 5401 kit and pointed out the bolts to ARP salesman over the phone. It was easy. Between Summit and ARP, you're looking at about 600 bucks.
Old 03-12-2019, 06:56 PM
Re: Case studs
$600 for bolts!
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V,
Old 03-12-2019, 07:51 PM
Talking Re: Case studs
Well if you have 5500 in just the crank rods and pistons and over 25,000 total in a supercharged 3.7 fed by 2 sts turbos you might want it to stay together
Old 03-12-2019, 07:53 PM
Re: Case studs
Thanks
thats the info I was looking for was also told not to go studs but to use the arp bolts
Old 03-12-2019, 07:56 PM
Re: Case studs
The ARP bolts can be torqued twice as much holding the block in place better for bearing clearance tolerance to stay consistent after line boring.
