Old 07-25-2012, 07:17 PM
Dessertrunner's Avatar
Re: Camshafts for the EG33.
At what revs did they say the hydrulic buckets will be a issue?
Tony
Old 07-25-2012, 07:25 PM
bazza bazza is offline
Tony
He didn't, said they can rev massive. Porsche run them, makes sense.
Old 07-25-2012, 08:17 PM
Tony
Tony, good news. I now have the stock cam profile completely mapped and found another place for regrind for 350. Thinking massive regrind and super tech 92 mm valves to allow for big changes although prolly not required.
Also I know what cam duration the 1200 bhp eg33 runs
Old 07-25-2012, 08:18 PM
The problem with the lift with hyd followers, is that the valves are too short, so that the spring binds at 9mm. Using solids and the longer WRX valves lets us use a longer spring, and higher lifts.
Hyd lifters are too heavy for high rpms. Have to use stronger springs to follow the cams, this causes cam/follow wear, and can end up pulling the head off the valve.
The lightest valve gear, is needed for high lift with short durations.
Old 07-25-2012, 09:51 PM
Kinda finding this hard to believe based on professional advice and other setups.
Example, rb20 wil rev to 10,000 +....
http://forum.r31skylineclub.com/index.php?topic=76252.0
Old 07-25-2012, 11:33 PM
Well mate you can believe whoever you want, but what I have stated is fact.
Example, rb20 Will rev to 10,000 +....
Read the thread, wouldn't call it authoritative, more like 'bench racing'.
Remember that some of the Nissans that have hyd lifters, use finger followers, which eliminates the weight of the hyd from the reciprocating valve train weight.
Old 07-25-2012, 11:51 PM
Interesting how you find all this info out.
I will stay out of the debut on valves, I am pretty sure there is info in the RIT mags on this issue.
Tony
Old 07-25-2012, 11:52 PM
Harvey what are bike engines doing with valves?
Tony
Old 07-26-2012, 03:32 AM
I'm sure it is. My information as above came from Kelford though who mentioned they've got no issues running hydraulics to many rpms.
Old 07-26-2012, 06:34 PM
Something rather interesting, stock cam profiles from the cam place:
Intake:
4 thou: 247.24 duration
50 thou: 187.75 duration
Lift: 7.1mm
Exhaust:
4 thou: 255.33 duration
50 thou: 194.17 duration
Lift: 7.9mm
My friend also supplied the stock head flow to the cam place and they've suggest 272 / 272 with 9.5 mm lift and around 225-235 @ 50 thou IIRC. Shall be rather interesting - that shop can claim supplying a certain 1200 bhp with it's cams also... cough *310* duration.. 12-13mm lift so we already know they're capable... should be interesting.
Old 07-26-2012, 08:18 PM
Tony
This is the cam/valves used in the Ducati 1098’s 550 cylinder that I compared .to the EG33 before.
The EG33 550cc cylinder gets 38.3hp at 5600 , and 38 ft-lbs at 4800.
The Ducati 550cc cylinder gets 58.5hp at 10,000, and 39 ft-lbs at 9500.
____________INLET__________EXHAUST.
TIMING____O/C 11* 58*_____O/C 60* 20*@ 0.002"
DURATION_____253____________260
LOBE CENT_____111.5___________110
LIFT__________11.8____________10.6
VALVE SIZE____41mm____________34mm
You can see that they rely more on the valve size and lift to fill the cylinder, while keeping the duration and timing as low as they can, to provide the strong wide, useably torque curve, while still developing the HP that gives the speed.
Old 07-28-2012, 06:06 PM
From my other thread:
EG33 spring height vs MY99+ spring height. EG33 using dual valve springs:
Gutted hydraulic valve (EG33) vs MY00 style shim over bucket setup. Gutted to determine hydraulic height and valve height for "solid" bucket solution. MY99 is to short. MY98 is to long. Doh!!
Old 07-31-2012, 06:17 PM
dynomatt dynomatt is offline
Bazza,
FWIW, the advice I got (from a guy who worked with Cosworth motors for many years) is you'll be wanting to chase the lift...I can't remember exactly but stock coil bind is around 9mm...even with different grade springs, you might be able to get that higher but to what end?
Solid buckets, shim under (not over) is really the way to go I think for reliable high revs. I realise people have had hydraulic buckets higher but is it worth it when valvetrain weight starts to become a factor.
Interesting on the drag motor...glad you dug that up. 310 duration is decent...must have idled like a ***** and had a very narrow peak curve.
The other thing worth considering is if you're doing a turbo build...a lot of the cam theory goes out the window in my experience.
M
Old 07-31-2012, 06:18 PM
And I'm sorry you mapped the stock cams. I'd also had that done about 5 years ago. Could have provided you the numbers...and the stock head flows too!
M
Old 07-31-2012, 08:02 PM
Originally Posted by dynomatt View Post
Bazza,
M
Indeed. Big lift would be nice. However when you start increasing lift and upgrading springs you turn the head into a full race head. Which means very high maintenance, increased risk of breaking valves, hammering seats and guides etc and this is something my mate and I didn't want to do or have to R&D. We want reliable track motors with mimimal maintanence which means keeping it close to stock design as possible.
So we're going to run 8-9.5 mm lift with massive duration - LAN already has shown these to work and Kelford show in there charts that this can easily be done. Something else to note is you don't actually need more lift than that - the stock heads flow huge amounts to that lift however above that lift the heads don't really increase in flow (based on our flow figures) - HOWEVER this flow still supports 400 maybe even 500 kw ATW. So as you can see there aren't really any positives for us running lots of lift for the planned 300-400 kw atw. Above that yes.
As for hydraulic buckets they're absolutely fine for my purpose. They'll do 6500-7000 rpm all day long:
http://www.youtube.com/watch?v=qssbthwIb4s
The only rule I stick with hydraulics is to use a SOFT RPM limiter only. A hard rpm limiter going off can pump the buckets up and you can lose compression in all cylinders for a few seconds.. BAD.
Solids would be nice but given the "PITA" factor and the cost I'd only recommend them for a NA engine like Jack's or what Tony is planning on building.
P.S. My mate wanted the heads and cams profiled to ensure we didn't make any mistakes - I believe his brand new billets arrive today
