Old 09-04-2009, 05:13 PM
FriendlyTurkey FriendlyTurkey is offline
Camshaft Spacing
I'm looking at doing billet camshafts for my EG33 with four cam gears driven off the timing belt much like the EJ205 and EJ257. Has anyone measured the camshaft spacing compared to the EJ DOHC heads? The idea behind this is to eliminate the internal gear drives.
Here is an EJ with 4 cam gears.
Regards,
FT
Old 09-04-2009, 06:19 PM
Re: Camshaft Spacing
Welcome to the forum. Can you please tell us more about youself?
Old 09-04-2009, 07:48 PM
I'm putting a EG33 in the back of a VW golf I have. Mid engine and ~2200lbs I estimate. These pictures are with a EJ18 mock up. I have the EG33 in R&D build up stage.
Old 09-09-2009, 11:13 AM
Found this article that was interesting. Note the four cam pulleys on this prototype for the EG33:
Old 09-09-2009, 04:54 PM
I have been meaning to toy with this idea for a long time... Adjustable cam gears are always nice. Not to mention you get rid of the scissor gears. You would need to use reground exhaust cams for the intake cams.
Old 09-09-2009, 05:00 PM
Have you verified the clearance between the gears Tom? I haven't had a chance to pull my head part to give this a try.
Old 09-09-2009, 05:07 PM
I can check center to center spacing as soon as tomorrow. But only between the cams on a single head, not X-block
Old 09-09-2009, 05:17 PM
That would be great Tom!
Where I'm going with this is having some billet cam blanks made up, but I'd like to do a single blank to save on production cost lowering the total cost of billet cams. It looks like I can get the cost of complete billet cams down to or below the cost of web welded cams.
Old 09-10-2009, 10:43 AM
I checked out the camshaft spacing last night. The spacing is insufficient to use factory cam gears on the intake and exhaust. I'm tracking down the possibility to use a smaller cam gear along with a smaller crank pulley to make this possible.
So far, billet cams are pricing out beyond what looks reasonable for a small run of 20. $650-950 per cam!
Old 09-10-2009, 11:32 AM
The factory camshafts have 48 teeth and are about 120.5mm diameter.
Honda B series cam gears have 34 teeth. I need to get a measurement on these for diameter, but they may work. I have to verify that the EJ257 timing belt has the same tooth profile as these gears before I go to far down this path.
Old 09-10-2009, 05:44 PM
superru superru is offline
just trying to fix it!
wouldn't changing the number of teeth (and diameter of the sprocket)
change the timing rotation in relation to the crankshaft? then also having to change the tooth count on the crank? someone let me know if i'm on the wrong path, sounds sweet though! maybe even adapting the STI :VVT into the newer cam design ..
uhh ya it's a subaru
Old 09-10-2009, 07:20 PM
Thats true. You would need to go to a 17 tooth crank pulley if going to 34 tooth cam pulleys.
Old 09-10-2009, 07:26 PM
Have you fitted stock 2.5l pulleys??
Old 09-10-2009, 09:39 PM
The stock 2.5 pulleys are still 48 tooth so I assumed they were the same diameter as the svx pulley. I may be mistaken.
Old 09-11-2009, 05:17 PM
I will see what I can find out tonight in my spare time
TOm
