Old 09-24-2008, 09:33 PM
sicksubie's Avatar
Intake....
Finished mocking up my intake tonight. Just need to weld, grind, and sand to finish it (maybe paint)... Here are some pics.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-24-2008, 11:43 PM
kpg2713 kpg2713 is offline
Re: Intake....
Looks sweet. Great Idea! You think it is actually worth any ponies? I would do it regardless but it wouldn't hurt
Old 09-25-2008, 03:05 AM
Re: Intake....
Beautifulll!!!!!!
Old 09-25-2008, 08:00 AM
sicksubie's Avatar
Re: Intake....
I followed YT's design and his gained 19whp on a N/A car.. On my supercharged car I would expect slightly more than that... Maybe, we will see when I hit the dyno...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-07-2008, 03:04 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Re: Intake....
Those intake pics look familiar.
This pic is of an intake I was making. Good luck bro. I wish u all the well. I gave up and asked Tom to make it for me with the same design concept in mind. Merging the single pipes together is the tricky part (Unless you somehow run dual air filters, which I'd think would be best overall).
Kevin Thomas
***R.I.P***
Old 10-07-2008, 07:23 PM
sicksubie's Avatar
Re: Intake....
Well if the new standalone set up eliminates the MAF then this intake will go on my new pearlie and a twin intake will go on my supercharged car...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 10-16-2008, 06:06 PM
downforlow's Avatar
downforlow downforlow is offline
NDP
Send a message via Yahoo to downforlow
Re: Intake....
i don't know enough about the electronics, but what would happen if you ran the dual intake with two MAF's spliced together? I've been thinking about doing that to mine to see.
- 1992 SVX Ls-l - ecutune 1v5, lightweight pulley, ram air, high viscosity head light fluid, low resistance muffler bearings, summer air in tires.
- 1994 SVX Lsi - true dual stainless, ecutune 1v5, custom body kit (less weight, better right hand cornering).
Old 10-16-2008, 06:33 PM
You would need a standalone to keep the two signals separate, I believe.
Old 10-16-2008, 06:34 PM
Re: Intake....
the airlfow signal also monitors air temp and density... wouldn't want to double those values
Old 10-22-2008, 06:18 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Re: Intake....
Deleted.... My post posted twice for some strange reason.
Kevin Thomas
***R.I.P***
Old 10-22-2008, 06:21 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Re: Intake....
I am not great in electronics as well. I thought about this and here's my conclusion.
1) The second most important thing to do is make sure that both intakes have exactly the same diameter,
2) The length of both intakes may not be as critical as the diameter. Try to make the lengths of both of them somewhat the same though.
3) If you want the airflows from both intakes to be similar, put a 'dead' or non-functioning maf sensor (The same type as the working one) in the second intake. This is to create a similar 'restriction' as the functioning one.
4) The most important thing to do is to be able to install a voltage multiplier (Is there such a thing?) in between the maf flow sensor voltage and the ECU. If there is such a device, you want this device to read the voltage and double the reading before it sends it to the ECU.
Those are my weird thoughts on this.
Kevin Thomas
***R.I.P***
Old 10-22-2008, 07:20 PM
XT6Wagon XT6Wagon is offline
Re: Intake....
MAFs have non-linear curves for airflow vs voltage. Also the curves before and after a maf will screw with the readings
