Old 10-22-2007, 09:15 AM
Evil One Evil One is offline
Pinto Boosting Freak
Send a message via AIM to Evil One Send a message via MSN to Evil One Send a message via Yahoo to Evil One
That translates to 32 lbs of boost from his two Garretts, so he is going to be needing the engine built pretty strong.
Joe, here are a few thoughts of mine on this.
If a person has the funds to build a custom 3.7 stroker engine, I feel he would invest a bit of time and money in the induction hard parts of the engine.
Ported head ports with bigger valves, improved intake manifold flow, bigger cams, ect.
This being said it is not unreasonable to assume the engine would make 300 hp NA.
With 300 NA hp it should be theoretically possible to make the hypothetical 700 hp on only 20 psi of boost with properly sized turbos and a good aftercooling setup.
Jim
1992 Dark Teal LS-L with 4.44 swap. NC Plate "EVIL I" *Dont Fear the GEAR*
1977 Ford Pinto baby blue with 79,000 miles
Old 10-22-2007, 09:23 AM
Jim
What about the drivetrain? You are gonna need one heck of a "tweaked" 6 speed...
Old 10-22-2007, 01:06 PM
I am just talking power here... it isnt my job to get it to the pavement
Jim
Old 10-22-2007, 01:26 PM
sicksubie's Avatar
I have read of guys who are putting donw 650whp in STi's that have a stock tranny. Granted the STi is 400lbs lighter
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-22-2007, 01:35 PM
I think that 500whp is conservative in our case... or reliable if you want
Old 10-22-2007, 02:29 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
Why not an auto tranny? Oops! I'm getting off topic.
Will be interesting to read more info about this setup.
Kevin Thomas
***R.I.P***
Old 10-22-2007, 02:33 PM
What setup?
Old 10-22-2007, 02:40 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
What setup?
Originally Posted by svxual View Post
just met a guy this arvo who reckons he building a svx with a 3.3 stroked to 3.7 wth a garrett for each bank..
That setup!
Kevin Thomas
***R.I.P***
Old 10-22-2007, 03:16 PM
Wink Close, but no seee-garr!
Jim
No Jim, that is still beyond even theoretical.
The set-up you mention will make around 630 hp at 20 lbs, assuming the turbos are big enough to deliver the airflow like you say.
To see 700 hp with such a set-up you would need 24 lbs boost.
Old 10-22-2007, 03:25 PM
I still think that a 3.7L stroker kit will make the walls thinner and unable to handle that much boost... Unless... something really crafty is done to strengthen them from the outside...
Old 10-22-2007, 03:29 PM
Wouldn't "stroked" only affect the crankshaft, rods and pistons? Why would the walls be thinner?
Old 10-22-2007, 03:32 PM
No Danny, in a stroke job [can I say that on here??] the piston and the bore remains the same. It is the crankshaft that is worked on to lengthen the stroke of the piston, the distance it travels top to bottom.
Longer travel gives the extra displacement.
In a rebore situation the thickness of the liner comes into play.
Old 10-22-2007, 03:34 PM
OK... are we talking crank or wheel hp here?
Jim
Old 10-22-2007, 03:37 PM
Oh sh!t.... I know the difference between stroking and reboring... I dunno why I thought of reboring when I read stroking...
I think I need a or a good night sleep
crazyhorse's Avatar
242,000 mi on oem trans
From what I've seen of the EG33's engine block, the open deck design may be the limiting factor in boosting it. The cylinders in an open deck block tend to "squirm" under boost. "O" ringing it will help, but to get the numbers you're talking about, I'm not sure that'd be sufficient.
Yes stroking the EG33 would only involve the crank & rods. The $64 question is, where would you source the crank? Are you saying that the Porsche engine has the exact same bearing spacing/diameter? The thoughts of an EG37 are VERY intriguing.
"42"
Current Stable By Age:
