Old 10-19-2007, 07:30 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by sicksubie View Post
In your crappy looking car?
Beg your pardon, you've never seen my car. You could eat off the engine!
Old 10-19-2007, 08:54 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Originally Posted by Myxalplyx View Post
Here's the horsepower:
STi Panel Filter: 158.17whp @ 6000rpm
ToMyx Intake: 177.31whp @ 6000rpm
+19.14whp
Kevin,
What I like most about the above graph for horsepower, is that the increased intake flow is really allowing the engine to come alive higher up in the power band where it previously fell flat.
What's very interesting though, is that w/o the ToMyx intake on, peak power is made around 5,400rpms which is similar to where an SVX on stock cams would reach its peak. With the addition of the ToMyx intake, peak power is made in the 5,800-6,000rpm range. Your gains are astounding, but an SVX on stock cams would probably not see as big of a peak gain as you did, but similar to what you saw, the area under the graph for both tq and hp will increase everywhere throughout the rev band.
I'm glad to see that you had the insight, resourcefulness and persistence to design and get this intake done! In good conditions, this car should run the 1/4 mile solidly in the 14's!
2006 Steel Gray WRX TR (sold)
Old 10-27-2007, 02:13 PM
mbtoloczko's Avatar
sans SVX
Wow. This has to be the most impressive HP gain I've ever seen for an SVX outside of nitrous or forced induction. Very nice.
BTW, did you guys monitor afr before/after? Would be interesting to see because the large change in intake geometry can affect air flow pattern through the MAF which can lean/richen the afr.
Mychailo
Visit my locker
Old 10-30-2007, 08:12 PM
curly2k3's Avatar
curly2k3 curly2k3 is offline
Own'eded
Send a message via AIM to curly2k3 Send a message via MSN to curly2k3
not bad man, glad to see your hard work and research paid off
98 Impreza Wago-O-Doom & Datsun Roadsters
Old 03-01-2008, 04:42 PM
GreenMarine's Avatar
From POST-***** to LURKER
Originally Posted by Chiketkd View Post
Kevin,
Wait a sec... So the test car was not on stock cams??
~ Chris
Old 03-01-2008, 05:04 PM
no, it does not have stock cams.
Old 03-01-2008, 05:05 PM
So it's not exactly an accurate test then is it? I mean, all things considered here, probably less than 5% of the owners on here have the cams, so the results wouldn't really be the same.
~ Chris
Old 03-01-2008, 05:07 PM
this may be true. I would expect that the similar gains would be seen through a stock motor as well all things considered
Old 03-01-2008, 05:45 PM
I'll be glad to test one of these for youguys at our dyno day in 2 weeks... We are getting 3 pulls on a Dynojet with a wideband O2 sensor attached... My engine it's self is "stock" with the only changes being a full Stebro exhaust with two "spun" metallic substrate primary cats. And ofcourse I have a 5MT not an Auto... But other than those small differences, It should provide a more accurate test...
~ Chris
Old 03-01-2008, 06:15 PM
~ Chris
That also creates a problem if you are looking for accuracy. I will be doing a lot more dyno work soon enough as there is a dyno relatively close to me that just opened. This is one thing I will try on a completely stock car exhaust and all to get the perfect numbers. I do appreciate the offer but I doubt I will have the next batch done in time
Old 03-01-2008, 06:42 PM
Myxalplyx's Avatar
XT6 is SVX's Daddy
**Deleted** No point!
Kevin Thomas
***R.I.P***
Old 03-02-2008, 09:19 AM
shotgunslade's Avatar
I don't have stock cams or exhaust either. So, I'm not a good candidate for a stock engine comparison. Do intend to take it to the dyno this year.
Old 07-14-2011, 08:47 PM
Huskymaniac's Avatar
Uses the ignore feature
Re: ToMyx Intake Vs Sti Panel Filter Dyno
Whatever happened to this?
Tony
Old 07-14-2011, 09:57 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
With All We'll Drive's closing, it's gone as well. JohnyBeas was supposed to grab that torch, but most folks are calling it a fumble.
