Old 10-14-2007, 12:13 AM
I have never had them tell me they are out of stock... I ordered a set for Sicksubie a month ago and got them the next day... They must like me more
Old 10-14-2007, 07:02 AM
Speedklix's Avatar
Locker Link Solution
I guess they just hate me then, called them at the begining of last month. It always sounds like the same girl, maybe it is just the way she handles sales?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-14-2007, 09:19 AM
94SubieSVX's Avatar
OOC for a while
If the WRX/STI mounts work with our cars, then couldn't we use aftermarket WRX/STI mounts too?
bLAh
Old 10-14-2007, 09:48 AM
Thats what the groupN mounts are
Old 10-14-2007, 09:51 AM
94SubieSVX's Avatar
OOC for a while
ooo...I should've known.
bLAh
Old 11-04-2007, 07:34 PM
svxpert svxpert is offline
can anyone tell if the Group N mounts are shorter than the stock SVX motor mounts? i'm looking for a set of motor mounts that are shorter than the stock ones as the project motor is slightly hitting the hood. maybe a 1/2 inch shorter would be great. thanks
Old 11-04-2007, 07:39 PM
groupN mounts on the stock brackets are 1/4" lower but the mount and the bracket need to be cut and ground
Old 11-04-2007, 07:41 PM
ok, thats a start. thanks
Old 11-05-2007, 09:36 AM
Jefus Jefus is offline
Jeff Williams
Send a message via AIM to Jefus
I cant find the site right now, I will post it later but i got my GroupN engine mounts and tranny mounts and the STI pitch from then. all if it just bolted in. I did not measure the engine clearance but did not notice any change.
Old 11-05-2007, 01:08 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
I used oem sti mounts and it raised the engine 1/4 to 1/2 inch. I used them with the sti brackets. Are the svx brackets shorter?
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 11-05-2007, 01:34 PM
The SVX brackets are made to work with the SVX mounts. The mounts are 1/4" taller in body. So using the sti mounts in the stock brackets with a 1/4" spacer, it will sit in the stock location. Without the spacer, it will drop the 1/4" or maybe more depending on the geometry, which is useful for guys who need hood clearance like the stage 3 guys and svxpert
