Old 02-23-2007, 08:03 PM
sicksubie's Avatar
Intake sludge question
Quick question: I am in the process of reassembling the intake stacks and manifold after polishing the heck out of them. When I originally took the intake tract apart there was a ton of oily sludge in the manifold and actually a puddle in the IRIS valve area. The stacks were equally disgusting and we won't even talk about the heads. My question is this can I put in a catch can in the two lines that run from each head to the snorkel? Would that elminate this sludge from building up again?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-23-2007, 08:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
1. It's normal
2. Install a new PCV valve
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 02-23-2007, 08:14 PM
sicksubie's Avatar
will that prevent the sludge from coming back?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-23-2007, 08:56 PM
SVXRide's Avatar
No, but a fully functioning PCV system will keep it from becoming excessive.
-Bill
Old 02-23-2007, 09:20 PM
It is a comon problem and you have to clean the intake from time to time. If the PCV valve is not working properly, it will build up faster.
Old 02-24-2007, 07:16 AM
immortal_suby's Avatar
Thread Killah
A few guys on the forester forum have installed catch cans with positive results. Go for it! Let us know how it works out - I"d like to try it also. Peaty on scoobymods has some detailed information on his install.
Locker Link
2015 BRZ Limited 6MT
Old 02-24-2007, 07:30 AM
Thread Killah
here's a link - but you will probably need to register there to view it.
http://www.scoobymods.com/forums/showthread.php?t=2769
Locker Link
Old 02-24-2007, 10:18 AM
sicksubie's Avatar
what about the lines that run from the front of each head to the very top of the snorkel ( by the TB). Those were the lines that I was really wondering about. I have the sludge all the way back into the snorkel and both sides of the TB.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-24-2007, 10:46 AM
longassname's Avatar
Just some dude.
We supposedly already have oil seperators in all of our pcv outlets...they just don't work very well. Particularly on these old engines. I'm starting to think that these engines start getting blow by but maintain oil control (oil control ring continues to function well) as they start getting up there in miles. So while they don't become oil burners they do start throwing more and more oil mist out the pcv.
Suggestions:
2 dual inlet oil catch cans to hook up all 4 lines.
dual inlet catch can to hook up the two lines off the block and add screening/mesh material into the oil seperators on the heads.
just add the screening/mesh material into the oil seperators on the heads
Do nothing until you build your engine and put the next generation of stage 3 on it--then install breather filters instead.
Old 02-24-2007, 07:52 PM
sicksubie's Avatar
Alright... After a very frustrating afternoon of trying to put the manifold on and breaking multiple hoses (I shouldn't complain at 159k they are pretty dry rotted) a very bad thing happened. I snapped the neck that the PSV hose attaches to. I got the new PCV valve in and was in the home stretch of getting the motor finished when this happened. I need to know if what I did was OK. I was able to connect the PCV hose to the neck but the other hose that runs to the snorkel is not happening. If I simply plug that hole in the snorkel what will the result be? Also, I used fuel line for the PCV hose, is that OK?
P.S. Thanks to Zavikan (James) for the PCV valve and hoses
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-24-2007, 10:59 PM
Thread Killah
that will be bad. you will build pressure in the crankcase. You need to try some epoxy or something to put the hose neck back on or maybe a brass fitting you can thread into the plastic or check ebay for an intake boot.
Locker Link
Old 02-28-2007, 02:33 PM
nextse7en's Avatar
Graphic Artist
JB weld works wonders for this, I just did somthing very similar.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 02-28-2007, 02:37 PM
sicksubie's Avatar
I bought hoses and the plastic neck from budfreak on sunday. They should be here soon and the car should be running by the weekend.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-02-2007, 04:10 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
You can install a catch can or do what many Corvette and Caddy mechanics do - go to WalMart/Home Depot/Harbor Freight/et al and buy a cheap air compressor water separator. Install it in the pcv line, lengthen as required. Drain at each oil change. Prolly less than $10.
Old 03-02-2007, 04:56 PM
sicksubie's Avatar
hmmmmmmmmmmm......... Tomorrow ( If budfreak got the stuff in the mail)
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
